Old 06-25-2017, 12:09 PM   #21
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Originally Posted by stykerdk View Post
6 or 7speed DSG because the 7speed DSG is some kind of s...
It has dry clutches and they dont work well seems like sliding clutches and hard shifting is almost standard with that 7speed DSG gearbox with code DQ200 which is rated for max 250nm.
The other DSG gearboxes with wet clutch like a MC is shifting very well and smooth
There is the old 6speed which is replaced with 7 speed now, so now they have 3 types of DSG gearboxes.
The 7 speed DQ200 with dry clutch you must avoid.
And two other 7 speed which is rated for higher torques than 250nm that has wet clutches, they shift very smooth if they are maintained with oil shift every 60000km-
I think the Toyota CVT is the only reliable CVT gearbox on the market.
There is Prius cabs in germany which has done more than 1million km with original engine and tranny.
It was the 6-speed DSG in a TDI. It was fine on the highway but I found it kind of jerky in the city. It even stalled out several times. I thought there was something wrong with it but the dealer claimed it was working normally. However that was also the dealer's claim everytime something else was wrong with the car. So... Also the DSG required expensive dealer only service every 40K miles. The most problematic car I ever owned. I will never own another VW.
Trying to find part numbers for yaris sedan 2011 front bumper conversion YarisSedan Cosmetic Modifications (Exterior/Interior) 7 11-30-2014 07:39 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
OEM Toyota Yaris / Vitz RS conversion botchilah Cosmetic Modifications (Exterior/Interior) 4 08-06-2009 02:47 AM
