#37 | |
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
#38 |
Bump if anyone could point me in the right direction to get my intake to work
#39 |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
If the screw holes are that far off it might be better to drill new holes and tap them if there's enough material. If not then I would say try and find a different intake or at least a section with a MAF mount. I think someone had one posted in the classifieds section on the forum. Can you put up a picture or two of the hole alignment?
#40 |
Does the sensor fit in the hole? The screws aren't esencial, they're just there to locate its orientation and keep it in place.
#41 | |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#42 |
Well if you have tools to make the hole bigger and get the sensor in there you can just seal it with a little silicone and zip ties.
#43 | |
2010EGGHATCH
Ill post updates Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#44 |
Just make sure it's oriented in the right direction and dead nuts straight.
#45 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#46 |
Never thought about zip tying the sensor down. That'll work! I'm guessing if I take a metal file to the hole ill be able to get it to fit. It's not off by much but enough to piss me off hahaha
#47 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#48 |
Nope neither lined up on mine. Both were off about 3-5 mm or so. The maf is less than a mm from fitting but it wouldn't go down. I'd say I'll be installing it this weekend coming & I'll let you know how it works out
#49 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#50 | |
2010EGGHATCH
![]() ![]() Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#51 |
I would be a little weary of the zip ties on the MAF, don't want any leaks there. Maybe you can make an adapter with some aluminum stock.
#52 | |
2010EGGHATCH
IG: 2010EGGHATCH |
#53 |
2010EGGHATCH
Honestly tho its sealed pretty tight it doesn't even budge
IG: 2010EGGHATCH |
#54 |
I gottcha, nothing beats the zip tie X, saved my ass more times than I can count haha. Glad you got it to work, nothing worse than not being able to use something you spent hard earned dollars on.
| Simota CF650-6 Air Intake Review | invader166 | Performance Modifications | 16 | 12-21-2015 03:31 PM |
| For Sale: Fujita F5 Cold Air Intake | invader166 | Items for Sale by private party | 2 | 11-21-2015 11:10 AM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| cold air intake | 400 dollar yaris | Performance Modifications | 10 | 10-02-2012 06:33 PM |
