Old 12-16-2018, 01:57 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Congrats, Adam!!! Such awesome news!
Old 12-17-2018, 10:00 AM   #2
DarkShadowFox
you know i forgot to ask, which gauge cluster did you use in the yaris and how did you fit it?
Old 12-18-2018, 04:47 PM   #3
DarkShadowFox
so in terms of the steering rack and subframe and assorted components how does all of this entire thing assemble into a third gen. can i get more detailed pictures, i have my entire GSIC for my yaris i just like to see the handiwork.
Old 12-22-2018, 09:24 AM   #4
atomic_hoji
Drives: 2018 Yaris SE 5MT
No changes to the steering rack, subframe or anything else under there. You need to the RH engine mount from the Scion xD - both frame side mount and engine bracket - but the dogbone and LH trans mounts from the Yaris work. Some careful movements and serious grunt and that gets the engine into the engine bay. Should find it's documented briefly here, and in more detail in one of the 2nd gen. swap threads.
I didn't take any pictures of subframe, etc.. because there were no changes needed - 1NZ out, 2ZR in with the xD mounts.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 02-23-2019, 11:56 AM   #5
logoris
Drives: 2017 Yaris SE Blue Streak
fantastic build, glad it all worked out.
It gives me some hope for mine once its paid off.
Id certainly like to meet the yw people in the gta
logoris is offline   Reply With Quote
2zr, 2zr-fe, 3rd gen, t-sport
Went and looked at a yaris Sport! mr_miles General Yaris / Vitz Discussion 19 02-20-2012 09:28 AM
