Old 10-20-2017, 11:36 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
? Drop oil pan to check pump pickup screen Toyota Yaris 1NZFE
(? Drop oil pan to check oil pump pickup screen Toyota Yaris 1NZFE)
Anyone done it? Looks like simple little flat pan on bottom of block...just need new gasket in hand...no other parts to remove?
Why? 141k mile motor feels like new, but sometimes seems like light clatter at cold start up-- sort of like a car that has hydraulic lifters filling or something. Then I recall friends Hemi Durango that had oil pressure light coming on and found oil pickup screen full of black crud...and photos on this Yaris forum of an ugly brown/black scene under the valve cover of one of these engines.
Dropping pan also finds engine parts, metal shavings, whatever, and is a way to remove all the dirty oil. Some might even stick a magnet to it inside.
Oil Pan removal to access Piston rod bearings tmontague DIY / Maintenance / Service 5 07-19-2021 12:45 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
