Old 10-21-2017, 02:57 AM   #8
eeeeeh
Drives: Yaris YR 2013
thanks @Justhandguns and @IllusionX. I have spare resistors lying around and don't think that helps with the LED brake lights. I just tested it and here are the results:
-- LED brake light on one side only, when I turn on the low beam, the LED would light up full-power. When I step on brake it would not make any brightness difference (so it is lit up).
-- If I turn off the low beam and step on brake, it would also go on full-power. BUT at the same time the low beam (and dash lights) would light up. This is why I think it is back-feeding power back to the low beam circuit, hence, my original hypothesis might be right where I'd need some diode to prevent this from happening.
-- I have also tested putting a resistor between brake and ground (LED brake light wires), which did nothing and arrived at the same result as above. I repeated the same test with resistor between low-beam and ground (LED brake light wires) and again, same result as above.
-- Previously when I replaced the indicator lights with LED I added the resistors in, and did not trigger any dash error lights.
Hmm.... more tests to be done.
eeeeeh is offline   Reply With Quote
ABS light on (without parking brake light) WildChild DIY / Maintenance / Service 15 05-06-2018 12:40 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
2007 yaris hatch back 3rd brake light (stop light) MegaMatt DIY / Maintenance / Service 12 06-15-2015 10:55 AM
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
