![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
New (Bad) MPG record
I've been tracking my MPG's since I bought the car. Last fill up yielded a calculated 28.05 MPG. My worst yet! Still I figure that's no too bad considering it was well below freezing the entire time and I was only doing short trips of 5 miles or less, sometimes in snowstorms with the traction control kicking in the entire way.
My previous worst was 28.80, 3 years ago, also in the dead of winter. For the record my lifetime average so far is 33.56. Best tank ever was 41.20. Auto transmission, mostly city driving. Can't complain. |
Cold winter tire pressure fuel mileage gas law
Check tire pressure...it is lowered by the ratio of temperature change (measured from absolute zero..."gas law"). Lower pressure creates more tire flex when the tire materials are stiffer because they are colder.
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Interesting how much climate & other factors can affect MPG within the same basic model specifications. As a contrast, my lifetime MPG average over the last 2.5 years has been 40.9 here in Phoenix, AZ - All city/suburb work commute & weekend errand driving, with the A/C running approximately 3/4 of that time (& I never need to use the heater/defroster at all). My lowest was 32-33 MPG back when I first got my car new (break-in MPG?).
Even if the tire psi is the same, the car will use up more fuel. Most likely the defroster is being used, so that kicks on the AC, which consumes fuel. Cooler air is more dense, so more fuel will be used. Most likely the heater is also on, so that consumes more fuel. There's probably more wind for the car to push through, and he already mentioned (having to plow through) snow.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
OP is not complaining about or questioning his bad mpg. Simply stating the fact that he has just set a new record low for himself. As I have recorded all fill ups since I got the car, I too will periodically check what I was getting during the same period in prior years. So far what I see is no significant change meaning my Yaris is performing just as well, or badly, as it was when new.
#6 | |
![]() ![]() ![]() Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
my 12 se averages 34.5 mpg. i'm not easy on the rpms at all, so that is a contributing factor im sure.
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
That is about my average!
Only super long road trips bump up my average. It's amazing how my car is 35-40 in suburban driving or 25-30 in the city. |
Drives: 2014 Yaris SE Join Date: Jan 2018
my 14 se averages 20.3 mpg. i'm not easy on the rpms at all, so that is a contributing factor im sure. l live in Chicago
I think my car is a problem. |
#10 | |
Out in the suburbs driving around I can easily get 40+mpg but in real city driving (30 seconds between lights and 20-30 seconds of waiting for the next green) it's barely over 20 if I'm lucky. |
#11 | |
are we talkin about driving down midtown competing against all the white vans and cabs and german cars?
aka red light, rev your balls off to 30mph until the next block. I do like 19 until i hit the west side hwy lol |
#13 | |
![]() Drives: 2009 Yaris Join Date: Apr 2015
Unless I am wrong, more fuel shouldn't be used. |
#14 |
When HVAC is in defrost setting you are utilizing the a/c compressor. It kicks in in order to extract moist air inside the cabin to combat fogging up.
#15 | |
However defrost does use more fuel since A/C kicks in. Thanks for clarify it. |
#16 |
Yaris HVAC rotary knob A/C Air conditioning defrost setting
Does A/C activate only on the most clockwise position/setting of that rotary HVAC distribution knob?
#17 | |
I also totally spend way too much time in drive through line ups - that has to hurt it too. |
#18 |
Drives: my car is the best Join Date: Feb 2018
| 2013 Yaris Really bad MPG??? | Pmansbridge | Fuel Economy Forum | 8 | 03-05-2018 12:48 PM |
| Tiny Fiat 500 earns an unimpressive 30/38 MPG & 27/34 with automatic | Kal-El | Off-topic / Other Cars / Everything else Discussions | 25 | 03-08-2011 08:48 AM |
| Winter Gas Causing Drop in MPG? | MadMax | Fuel Economy Forum | 66 | 03-21-2010 05:46 PM |
| Why is my new 09 Yaris MPG is so low | soup1207 | Fuel Economy Forum | 34 | 06-12-2009 04:45 PM |
| The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 09:38 AM |
