![]() Drives: Yaris '07 Join Date: Dec 2010
yaris 2007 1.0 MAP sensor
hi guys!
can someone tell me where the map sensor is located on the 2007 yaris 1.0( 1krfe engine) ? How can it be cleaned? The same way you clean MAF sensors? Show me some pictures indicating its location if you can. Regards |
It is located under the air filter box and just behind the throttle body. From what I have heard, MAP sensors are not as fragile as MAF sensors, so most people clean them with carb cleaner or brake cleaner.
Drives: Yaris 2007 1.0 sedan cvt Join Date: Nov 2016
thank you I have been searching for this, at least past 2 hours
![]() Drives: Toyota yarris 1.0 2008 Join Date: Mar 2018
Hi there. You have only been looking for the MAP SENSOR. Try 4 days. I looked every site to find out where to locate the MAP sensor on (1 KRFE engine) but all YouTube clips showed every other module but ours. At thanks to this forum I will be attempting to clean it. Can I use STP brake parts cleaner as I have seen a YouTube clip showing some one using it? Also can anyone send a image where to locate the PCV VALVE? Thanks
Sorry for missing words. It’s the freezing cold weather to blame
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
