Old 03-05-2018, 12:46 PM   #1
Jeanseb29
Drives: Toyota Yaris RS 2011 (HB)
I would try cleaning the MAF sensor and the throttle body. You can buy both cans of cleaner at Canadian Tire for less then 20$. After that, disconnect the battery for a couple of minutes to reset the ECU. Once the battery is reconnected, start the engine and let it idle for 10-15 minutes. Drive for a day or two and come back here to tell us if you noticed an improvement :) - JS
Sent from my SM-N910W8 using Tapatalk
Jeanseb29 is offline   Reply With Quote
Old 03-06-2018, 04:14 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Take this advice. These are very simple jobs and can make a world of difference. This simple service both smoothed out my idle and generally made the engine run better through all rpm ranges.
motorbike engine swap ACKING_QC Performance Modifications 6 05-12-2021 03:08 PM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
