![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Like I mentioned below you dont adjust ebrake with star.This is from what toyota mechanic said.
I am folling this tutorial and turn star just like pic mentions..http://www.yarisworld.com/forums/sho...t=12333&page=4 |
#2 | |
First check that your adjuster only spins one way. It should only be able to be turned upwards and it should clicks as it turns. My sister in laws recently purchased used 07 Yaris had the same issue on one of the rear shoes. It looks like it is installed properly but the one of the ends of the star adjuster is flipped and because of that it will not ratchet. This leads it to always backing off and loosening your e brake. I am also confused as to what you have actually checked vs what is being glossed over and assumed correct. Or just go to the Toyota tech you talked to and have him fix it. But trust us when we say you do not need to touch the adjuster at your e brake. All the adjustment can be had at your star adjuster even for those that track their cars. This is assuming that everything is installed correctly, and I am not all that confident this is the case here
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Yaris with rear disc brake from factory? | tamrat | DIY / Maintenance / Service | 18 | 01-19-2016 09:08 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
