Old 06-10-2018, 11:58 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by DarkShadowFox View Post
what you should do is, either hardwire in a power line from a line somewhere with taps that runs the headlights and get the fog lamp button and slap it on your pop out panel.
or get the stalk that has the foglamp switch on it and tap your headlight harness. and or look for your connectors I think the yaris is either prewired or can be wired dont ask me how.
Pull handbrake, start car, DRL are off. Release handbrake, then fogs turn on. I can switch it off as I wish.
Turn on the headlights, and fogs turn on or off as it should, and turn off automatically on high beam.
Sent from my ONE A2005 using Tapatalk
Disable DRL on 2012 Yaris Le ucsmfu Third Gen Yaris General Discussion 12 09-16-2015 10:29 PM
enable DRL at Yaris 2009-2011 Ot_tO DIY / Maintenance / Service 6 06-15-2012 05:13 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
Disable DRL and keep Fog Light function!! chino_potato DIY / Maintenance / Service 10 06-23-2007 01:01 PM
