Old 06-19-2018, 06:08 PM   #1
Runethecursed
Drives: 2009 Yaris S
Originally Posted by tmontague View Post
That's about the amount that I have on my drums and it seems to work well
Agreed. The self adjuster rarely works properly in most cars and especially not in the Yaris. Is recommend adjusting every 6 months depending on how often and how hard you use your Yaris
That's exactly what my issue is. I think adjusting them now
Also I have the disc rear axle beam part number if anyone cares... I want disc rears just cause haha
Runethecursed is offline   Reply With Quote
Old 07-16-2018, 04:13 AM   #2
BennyLava
Drives: 1987 Silverado
A late update:
I adjusted the rear brakes manually, and it fixed the problem. They have returned to their previous feel. Also took the time to clear coat the shiny metal drums. Hopefully that clear will hold up over the long term against the rusty look.
BennyLava is offline   Reply With Quote
Old 06-19-2018, 02:04 AM   #3
I'm going to guess some how air got into the system. Not really sure how that's possible, but a squishy brake pedal is a sign of air being in the system.
Do a brake fluid flush with some DOT3/4 fluid, and see how it feels then. It's probably due for a flush anyway. I'll be flushing mine (probably with the gravity method unless I can have someone help me by pressing on the brake pedal) soon. I've flushed it once already, but I used Torque RT700 (DOT4), but it's changed color quickly (even became a little jelly in my FR-S [sucked out and topped off with new fluid for now]). I have some Amsoil DOT3/4 waiting for both cars, just need the time to do it.
Old 06-19-2018, 03:36 AM   #4
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
When I bled my brake, I cut a $2 1/2" pvc pipe from home depot, pumped the brakes, placed the pvc pipe between the brake pedal and the seat, and made sure to place a cardboard piece between the seat and the pvc pipe to avoid any damage. Seemed to work well.
07liftback is offline   Reply With Quote
Mysterious Brake Fluid Loss xdarkxfirex DIY / Maintenance / Service 5 09-30-2017 09:18 PM
98k mile A/T fluid change and it's wierd?!? 07stlYaris DIY / Maintenance / Service 6 10-11-2014 02:38 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-27-2012 12:48 AM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 12:53 PM
Anyone have their brake pedal go rock hard on hot days? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2009 12:20 PM
