Nothing to look at really unless you were going to replace the cable yourself. Quick tip, if the 10mm bolts are seized that hold the e brake cable to the body just use zip ties. I had to do that on my old echo as all the 10mm bolts snapped off and I couldn't remove them w/ easy outs and zip ties worked great.
chances are your e brake driver side cable it seized due to lack of use. Once those things seize there is no getting them to un seize
| Passenger side caliper loose... | baseballfan416 | DIY / Maintenance / Service | 5 | 08-17-2016 10:35 PM |
| Replace 2008 Yaris D4 sedan passenger side window | harvey | DIY / Maintenance / Service | 0 | 08-01-2015 02:53 PM |
| Enginge bay rattle on passenger side - advice | aliasofmike | DIY / Maintenance / Service | 11 | 02-26-2012 12:00 PM |
| Wet floor on the passenger side? Got it! | nemobile | DIY / Maintenance / Service | 8 | 01-20-2012 12:57 PM |
| Noise on the passenger side with audio | zachryboles | DIY / Maintenance / Service | 1 | 10-19-2011 08:32 PM |
