Sorry, it was supposed to say "coolant sealer" those liquid seal-a-leak things that are harmful long term for your engine and other parts
![]() Drives: Yaris YXR ‘05 Join Date: Jan 2018
So, thermostat is good (tested out of the car), water pump seems good and turns freely and quietly by hand. Coolant level is good, no air bubbles seem present.
Driving between 70-100km/h after 10 minutes the coolant temp goes to 90c and starts climbing rapidly (1degree every 3-5 minutes). Then I turn the heater on full, cabin fan on full and the temp drops to 85-90c and sits there rock solid. The air is blowing “scorching desert wind” hot and after a 30 minute drive the top rad hose is still cold and soft to squeeze. Starting to smell like a blocked rad to me unless I’ve missed something? |
#3 | |
New rad went in and the car won’t go over 81c now with the AC on full and heater tap closed. Hopefully there’s not more of this crap in the galleries. |
#4 | |
I have personally never found the 1nz to he hard to burn if you have the front jacked up, I just over fill the overflow reservoir when I'm re filling an empty system and after driving around a bit it will burp itself and pull from the overflow. But as Barber stated, the funnel allows you to do it all in one shot in your driveway and is a convenient tool
![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
Temp above 105C
Hello,
Can someone please help, when am on highway instead of my temperature staying below 90C it goes as far as 105C or more. I have changed gasket, coolant and rad cover. However what I noticed is that whenever I am descending the temperature rapidly goes back to normal, is this a problem with breeze not getting to the radiator when moving on a flat surface? I will appreciate all the help I can get here. Thanks |
| Tags |
| cooling system, overheating |
| 1nz turbo with recipe! | speedworxs | Forced Induction Forum | 61 | 06-27-2019 04:00 PM |
| Polishing 1NZ Throttle Body | rabbito | Performance Modifications | 3 | 02-25-2016 11:36 AM |
| 1nz Disassembly & Reassembly. | EchoLaQua | Forced Induction Forum | 0 | 06-19-2015 11:17 AM |
| Overheating problems | scumfromohio | DIY / Maintenance / Service | 24 | 04-18-2014 02:09 AM |
| ATX temperature overheating? | yaryarbing | Fuel Economy Forum | 7 | 05-07-2011 09:24 AM |
