![]() ![]() Drives: Sedan Yaris 2010 Join Date: Dec 2017
Am reading the temp from my scanner (Blue driver), I once flushed the radiator before putting in a new coolant. How do I know if the temp sensor is bad? By temp sensor, do you mean the ambient temp because that one isn't even existing on the car? (May have pulled out without me knowing). Though I don't know where the scanner gets a reading of 81C from since the sensor wasn't existing.
On the gasket, I was driving on the highway and I suddenly saw the overheating light on the dash, thereafter I was told my gasket was bad because coolant gets thrown out if I start the engine with rad cap open. After changing the gasket, my temp hasn't gotten beyond 110C but I think it's just because I now actively monitor the temperature as I think it may have overheated otherwise. Thanks for helping out so far. |
#2 | |
Nope, the gasket change happened earlier in the year, when I had overheating light and my belt is fine.
#4 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
Once the car reaches operating temp (once the cooling fan starts cycling on/off) you shouldn't see any bubbles or foaming at the top of the radiator. Your long term fuel trim value of -13.3 indicates the car is running rich which seems to be validated by the poor fuel economy you're experiencing. |
| Tags |
| cooling system, overheating |
| 1nz turbo with recipe! | speedworxs | Forced Induction Forum | 61 | 06-27-2019 04:00 PM |
| Polishing 1NZ Throttle Body | rabbito | Performance Modifications | 3 | 02-25-2016 11:36 AM |
| 1nz Disassembly & Reassembly. | EchoLaQua | Forced Induction Forum | 0 | 06-19-2015 11:17 AM |
| Overheating problems | scumfromohio | DIY / Maintenance / Service | 24 | 04-18-2014 02:09 AM |
| ATX temperature overheating? | yaryarbing | Fuel Economy Forum | 7 | 05-07-2011 09:24 AM |
