09-28-2018, 06:08 AM | #19 | |
Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Looks awesome! I don't think you're "planning a swap" anymore - you're neck deep..
-- Adam |
09-28-2018, 06:42 AM | #20 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Right on, engine looks to he in good shape.
Do yourself a favor when the engine is still out of the engine bay and easily accessible - remove as many bolts as you can and cover them in anti seize. Specifically the exhaust manifold bolts, intake manifold, fuel rail etc. Also remove any hoses and spray silicone lube on the metal fitting/inside the end of the hose and re install. You have no idea how much easier this will make your job down the road if you ever have to remove anything.
No one ever wants to give a Yaris the point by... |
09-28-2018, 04:17 PM | #21 | |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
I'll be honest. The thought of the diagrams frightens me LOL. But, I will get a short-term membership. I may come 'knocking on your door" for advice on the specific ones to get if I get into the system and become overwhelmed. Thanks Adam.
09-28-2018, 04:31 PM | #22 | |
Yes, I think I'll really enjoy playing with the engine before installation. My timing cover bracket is "on order" from the online Toyota Parts dealer, so I'll have a bit more time to do what you suggest regarding anti-seize/silicone. I also ordered a PCV valve (See...I'm listening! ). Thought I'd install that before the engine is put in. I should be ok, right, not installing a catch can setup like you did? I won't driving the snot out of it. I think you mentioned that you installed a Scion upper rad hose or filler neck, did you not? I really want an OEM look and will be searching for an engine cover. So far the ones I've seen online would require me to remortgage my house to acquire. Sometimes local pricing can surprise - in a good way. I'll keep looking around here. Q: If I keep the Yaris filler neck and rad hose, I wonder if the engine cover would fit? May have to just find out after. Finally, and my apologies for the long-winded response... Your pics from your thread are gone, Photobucket, I presume. Wondering if you'd be amenable to zipping those up (if you still have them , of course) and firing them off to me in an email. I'll totally understand if you don't want to take the time as you guys are already being amazingly helpful and I don't want to 'overstay my welcome'. I'd of course keep in mind that your swap was with manual, but pics might be helpful. Thanks Trevor.
09-28-2018, 04:43 PM | #23 |
Excellent! Glad you're coming along for the show. It could be amusing. LOL!
09-28-2018, 07:55 PM | #24 | |
You will be fine without a catch can, just run a good oil and change it frequently. Also avoid only doing short trips in the winter, my catch can picks up a lot of water in the winter months. Yes, I run the xD upper hose and filler spout which I highly recommend. It mounts nice and solid to the already existing 2 holes on your fan shroud. It also places it at a high point which makes bleeding the coolant easy. Iirc I bought mine from village scion online in the states and it wasn't too much, I think around $40 usd for it all. Btw there are technically 2 hoses as one is just a short 2 inch straight run that connects the fill spout to the radiator. The other is long and runs from the spout to the engine. You realistically could forgo the short one and just cut a piece of existing 1nz hose and make it work. It only cost a few bucks and I didn't want to leave anything to chance so I bought it as well. I actually was using FB to host my pics but apparently they seem to sweep the url's clean every few weeks as all my pics seem to be been broken links now and this happens every few weeks. I can post the pics back when I get a chance but I will be busy the next couple weeks. Email me any pics you specifically need and I can send them to you. I have pics of the maf power wire I spliced in which will help you
09-28-2018, 09:00 PM | #25 | |
OK, I will let you know which pics will be helpful. I'd definitely take the MAF wiring anytime. But, like you say, you're definitely going to be busy for the next while. Haha. Hope yours sleep better through the night than ours did!
09-29-2018, 08:23 AM | #26 | |
Just need the actual hose now. I also compiled - hopefully - all the parts I need to mount the alternator.
09-29-2018, 08:55 AM | #27 | ||
Once you get the hang of the System Circuit diagrams they're actually pretty straight forward - Toyota does a pretty good job of laying them out and labelling, etc.. And YW folks are always here to help! Like Trevor I also run the upper xD hose and filler neck - the Yaris setup ended up interfering and in the way. I also ran both xD heather hoses as I found mine were kinking to run from the 2ZR to the Yaris firewall - not sure if Trevor, Sam, or Tom found that they needed those or not. I need to get one of those fan belt adjusters - my home brew made from flatbar is doing to the job, but I suspect is slipping a bit... lol Can't wait to see the accumulated pile of parts ready to go! -- Adam |
09-29-2018, 01:37 PM | #28 | |
I did opt for the xD rad hose/filler combo as suggested by Trevor. I'll also check in with Trevor on how it went with his heater hoses 'adaptation'. That reminds me...I'm wondering if the rad hose diameters are similar enough to use my old spring clamps. I plan to get on to TIS or identifix this evening and have a look for the diagrams. Then, let the downloading begin. Thanks!!!
09-29-2018, 02:24 PM | #29 |
Here is a list of rad hose related parts for the xD. Not sure which I'd need but hopefully not all. I suspect that many are already in the Yaris or are not used. If anyone was willing to say you just need A, B. C etc that would be great. I am already getting the upper rad hose (16571-37090), Filler Sub-Assy Water (16502-37010) and Hose 3 (16573-37030). I'm hoping that's all I need.
I am getting a membership to identifix or TIS and will be learning about the various wiring for the Yaris, Corolla and xD. This will be time-consuming for me as it's new to me so I'm all ears for tips as per rad hoses etc in the interest of saving time.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-29-2018 at 02:45 PM. |
09-29-2018, 05:26 PM | #30 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
This is Awesome!
09-29-2018, 06:35 PM | #31 |
09-29-2018, 07:40 PM | #32 |
More Parts for Alternator, Radiator and Engine Mount
Extra parts:
09-29-2018, 09:07 PM | #33 |
I still don't know what purpose that engine mount stay does? I have it on my engine but I can't see it doing much for support
09-29-2018, 09:34 PM | #34 | |
Oh, BTW, Trevor, I think you said that you used your Yaris heater hoses. Is that correct and did you have any issue with reusing them? New ones aren't prohibitively expensive, but if I can save a buck or two here and there, I will. Thanks.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-29-2018 at 10:41 PM. |
09-30-2018, 08:45 AM | #35 |
Quick question before I dive into the wiring diagrams...
Can I use the Corolla timing cover bracket mount bolts to attach the xD bracket? Not sure if there is a difference in bracket thickness and if the bolts are long enough or too long?
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-30-2018 at 09:04 AM. |
09-30-2018, 12:51 PM | #36 |
Data doesn't lie
They are the same bolts, I reused the corolla bracket bolts on my xD bracket.
I agree. I never installed that part |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
