Old 10-02-2018, 06:06 AM   #1
miiser
miiser's Avatar
Drives: yaris 2009
ASAP information+opinions for Android Headunit.
Originally Posted by 06YarisRS View Post
Congrats on the purchase! I think you'll be pleased. Poweramp has all the EQ you'll need. It has a 10 band equalizer plus all kinds of filters etc. Once you get the unit installed and PowerAmp loaded, there are a few settings in Poweramp and your system settings that I can help you with. To reiterate what ern-diz said, a bit more power is better. Since you've already installed speakers, that's the hardest part of an audio upgrade. I bet that you'll be looking at an amp, sub and tweeters before long! Haha. Trust me, it would make a world of difference. There are some good 4 channel mini amps in the 50/75 RMS x 4, CEA-2006 approved category that rock. If you go that route, I can make some suggestions on budget gear that's pretty good quality (Clarion, Kenwood, Korean-made Dual amps, NVX etc, no Boss/Pyle gear here LOL)
Thank you, I hope I will be pleased.
I would love some help with these settings since I am new to this. Thank you
So poweramp applies eq settings in the whole system? Or just the songs I play within the app?
Haha once you get in the sound upgrade path, you can never stop. I was always wondering what people think when they turn their cars into a transformer full of speakers and when I decided to upgrade my sound system, the list went on and on and on.
I made some mistakes in the beginning, I bought a pair of speakers that I shouldn’t have, because they had build in tweeters (coaxials) and I placed them in the front, while I had already tweeters from the factory in the a pillars, so there was no depth in the sound, no bass, only highs.
After that I bought the other set which I have right now. They are stock speakers from VW group, but to me, they sound amazing (I have upload some pics of them in an other post I made about some interior upgrades I did, and you can really see the difference in quality between them and the stock Yaris speakers : Neat-cheap interior mods that makes a huge difference.
https://r.tapatalk.com/shareLink?sha...0&share_type=t
I had experience with them before due to our previous car (Audi a5) and I knew that their stock speakers are pretty good, so I bought 4 used of them and I couldn’t be happier. Total cost of them 40$.
Now with the new HU I think they will shine.
For now I will try to hold myself from spending more money on amp and sub. But I know that at some point I will do it for sure
miiser is offline   Reply With Quote
Old 10-02-2018, 09:12 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
The question about Poweramp applying settings to the whole system is something I'm not sure about actually. I don't use any other sources, so couldn't say for sure. The Android unit will have an EQ under the sound settings. I normally leave that flat and the use Poweramp for my 'frequency tuning'.
Sounds like those speakers will work well. Most aftermarket speakers, whether low or high end, I believe, will not come into their own without an amplifier. Maybe the low impedance speakers like some of the Polks or Infinitys would give better results with head unit power alone. I think OEM speakers are more efficient, demand less power, and as a result may sound better than aftermarket if powered only by a stock head unit. My experience has always been that just adding an aftermarket speaker will improve the clarity, but results in less perceivable bass response.
Old 10-03-2018, 04:51 AM   #3
miiser
miiser's Avatar
Drives: yaris 2009
That’s exactly what I figured out, too.
I bought these speakers, because they demand less power and they work really well if you are on a budget. With a new HU, with more settings than our factory one they can really shine. Even with the crappy stock Yaris speakers you can improve the sound by using a new headunit, or at least that’s what a member here told me.
With aftermarket speakers you have to get an amp sooner or later otherwise you miss depth and bass response.
So to anybody else who’s thinking buying a new pair of speakers, without having an amp, guys buy a pair of used factory speakers of another, more expensive car (I heavily recommend the vw speakers, but it’s up to you). Just make sure that the ohm independence is 4ohms if you are going to use them with the stock headunit .
They will make wonders.
Need opinions on these wheels ASAP! PumpkinSteve Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-16-2011 02:26 PM
Need some new headunit opinions pvt_melfi13b In Car Entertainment + Electronics (audio / video / alarm) 10 06-28-2010 06:54 AM
