Old 11-20-2018, 08:47 PM   #1
tmontague
tmontague's Avatar
OBD II based etest pass with 2zr swap
Well, it's been confirmed. In Ontario I passed the etest with a swapped 2zr and an xd ecu. It should he noted that i used tech stream to rewrite the chassis VIN into the ecu. You ca n pay the dealership to do this or do it yourself with the software and cable like I did. However, you should still pass with a different EVU VIN they just might ask you if you have replaced the ecu and you can say you did so due to the original one breaking.
They never asked me any questions and it passed as usual. Ontario no longer requires etests for non commercial vehicles as of April 2019, but I needed mine for January.
Figured this is useful info for anyone who lives in a jurisdiction that requires an etest that is simply an OBDII scan.
Let's the swaps begin!
Old 11-20-2018, 09:24 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Congrats! That's awesome. So they don't stick a probe in your exhaust pipe? Just OBD2 scan for emission related codes? We've never had emissions testing here in NB - too rural, I guess. LOL
Old 11-20-2018, 09:46 PM   #3
You, however, have to submit to a safety everytime your tags renew. We don't. Only safety checks our vehicles see here is when they change ownership.
Sent from my EML-L09 using Tapatalk
Old 11-20-2018, 10:37 PM   #4
06YarisRS
True. In fact I have one coming up at the end of the month. My van, this time. It should pass.
Old 11-23-2018, 02:07 AM   #5
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Same thing here in California. Taylor passed the OBD smog check with the correct vin in The ECM
ArmstrongRacing is offline   Reply With Quote
Old 11-26-2018, 03:41 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
So it's possible to go 2ZR swap here in CA and stay road legal, correct?
On Instagram
On Wheelwell
Old 11-26-2018, 04:02 PM   #7
ArmstrongRacing
Data doesn't lie
That’s correct sir, but you need to re-write the vin and engine info to the new ECM.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 11:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 09:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 10:12 AM
Information for 2zr fe engine swap in my 2012 ncp131 Yaris 20yaris12 Third Gen Yaris General Discussion 0 07-03-2016 01:00 AM
