Old 01-04-2019, 08:02 AM   #1
ojeysky
Drives: Sedan Yaris 2010
Originally Posted by Yaris709 View Post
Just wondering if the newer type led's with the heat sink on back will work in the h4 yaris headlights? Since the h4's have that rubber seal around the back of the bulb. And a good bright reputable led if anyone knows what brand is good!
I recently purchased one of these and I am having a hard time fitting the rubber seals. Any suggestions?
ojeysky is offline   Reply With Quote
Old 01-04-2019, 08:05 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
I had to cut the 4 nibbles out. You have to install the holder, out the rubber on and turn to lock the LED in place.
Old 01-04-2019, 10:43 AM   #3
ojeysky
Thanks for the hint will do just that. However there seem to be another issue, the hi-beam blue icon no longer show up on my dashboard, is that normal? It normally show up when I used the OEM bulbs.
Update: So it happens that one could turn the cover around to fit instead of cutting it. I have attached picture for anyone who may find this useful.
Old 01-04-2019, 12:16 PM   #4
ojeysky
Just as a follow-up, I returned the osram halogen bulb and the high beam indicator came back on, I then plugged back the LED same thing no more high beam indicator. What could be the fix to this?
Old 01-04-2019, 12:20 PM   #5
IllusionX
Normal. Resistance is different, and the icon don't show up when using LED
Old 01-04-2019, 01:04 PM   #6
ojeysky
Ah thanks that's good to know.
Regards
PS: Your fuelly hyperlink doesn't redirect to your page.
Having a few very very odd issues after LED conversion Astroman In Car Entertainment + Electronics (audio / video / alarm) 8 08-03-2014 05:53 AM
Does anyone realize yarisworld is getting 'less busy'? caineroad General Yaris / Vitz Discussion 84 11-05-2013 12:19 AM
FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video V70R_Blackbrick California 4 10-13-2013 10:57 PM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 01:10 AM
Cruise Control kicking itself out GTBaker Third Gen Yaris General Discussion 9 09-05-2013 09:39 PM
