Old 01-22-2019, 01:01 PM   #2
komichal
Not sure about your engine but the process was fairly easy on my 2SZFE.
Mine was pretty dirty so I cleaned it up during one big maintenance. The engine felt better afterwards indeed but there was a number of actions taken (cleaning MAF, changing plugs, oil, cleaning PCV) simultaneously so I cannot say how significant the throttle body cleaning was.
There was no need to reset anything (well I had to reset one error code because I forgot to unplug battery before disconnecting MAF). To my knowledge throttle body re-adjusts itself after the computer learns the new mixture ratios after a few (dozens) kilometers.
Not sure what TB you have cleaned before so just let me repeat that you need to open the TB with ignition ON and by stepping on gas pedal. Do not try to move it with hand. But I guess you know this. :)
1zz Throttle Body - what needs to be done to it kac Performance Modifications 25 11-20-2018 06:13 PM
Throttle body question Yaris 2007 1290cc Byron05 DIY / Maintenance / Service 5 06-28-2018 09:36 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
