Old 09-13-2007, 01:10 AM   #1
caveatipse
Drives: 2007 Black Yaris
Most of this info has been posted before (#73, 78, 84)) and in a few other threads, but for those of you who missed some of it...
As I understand the situation, Toyota did not include the A/C filter because the filter frame will not fit due to the position of the blower. Toyota believed that if the filter frame could not fit, then the filter could not be installed properly. The frame and filter are an assembly unit. So, they just left it out! It's that simple as far as Toyota was concerned.
Unfortunately, the owners manual refers to the A/C cabin filter probably because it should definitely be standard equipment and it was assumed it would be... only later to discover the filter frame wouldn't fit. More unfortunately, the dealers know absolutely nothing about this situation and are totally in the dark when confronted with it. Seems to be a breakdown in communication at several levels.
I only discovered that the car had no filter when something from my glove box got sucked into the blower and began making all kinds of noise. Other yarisworld members have had the same experience. Indeed, it is a problem!
Thankfully, we at yarisworld have found that a filter will in fact fit (with a bit of gentle massaging) and function quite well without the filter frame. It's a quick, easy, and inexpensive install.
At this point, we've learned that a Purolator filter #C38188 and Bosch filter #P3750 will fit adequately right out of the box.
So now the qustion has risen once again... what will Toyota and/or the dealer do about all this?
The Toyota filter also fits just fine without a frame.
caveatipse is offline   Reply With Quote
Old 09-13-2007, 06:16 AM   #2
black2yaris
The Man In Black Lives
Drives: Black Sand Pearl L/B 'o7
But the others are cheaper in price !!
black2yaris
The Man In Black Lives!
2007 2 door hatchback in Black Sand Pearl, A/T,rear spoiler,front & rear JDM badges,TRD CAI,TRD rear sway bar,exhaust tip,sill protectors,heximats,under dash blue LED's,short rubber ant,rear bumper protector,Toyota thin 7 spoke alloy wheels,pwr pkg,ABS,side curtain airbags,rear defogger,fog lights,mud guards,TYC tail lights,shift knob,tint all windows,security sys,keyless entry,clear paint protection all exposed front surfaces,TRD fuel cap,rubber dash & g/b mats
black2yaris is offline   Reply With Quote
Old 09-12-2007, 05:54 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Just a note - I have a 2007 4-door hatch and my car does have a cabin air filter. Also, the dealer knows about the filter, and even my service schedule recommends it being changed every couple of months due to potential mold/blockages. BTW, I live in Canada. :)
devinlamothe is offline   Reply With Quote
Old 09-12-2007, 10:19 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Well, the sedan probably has a cabin A/C filter quite simply because it is not a Yaris; it is a Belta, designed and built by a different division of Toyota. I assume the blower unit fits in the Belta such that the filter and frame assembly can be installed.
Old 03-25-2009, 09:12 PM   #5
JBougie
JBougie's Avatar
My sedan did not come with one - after we bought the car that is something that my husband looked for. I called the dealership and they said that Toyota doesn't supply them, but I could buy one from them for $40. That will never happen.
I am going to be buying one of the ones suggest in this thread however, because I have been trying to find one that would fit.
JBougie is offline   Reply With Quote
Old 03-26-2009, 12:29 PM   #6
b_hickman11
Drives: 08 Sedan
Go to your Local O'Reilly Auto Parts. They have them and they are only $8.99 and they are a perfect fit. Item # 3679
b_hickman11 is offline   Reply With Quote
Old 03-31-2009, 12:56 PM   #7
1stToyota
1stToyota's Avatar
And they should be good for about 15K miles, so about $20.00 for 2 years worth. Sure beats the heck out of one with a filtering surface area that's half cardboard and duct tape.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 09-12-2007, 09:33 PM   #8
Super_BQ
Drives: 2006 New Zealand Model
I have contacted (by email or phone) the Toyota offices in Greece, Europe (Belgium) and Japan and they gave me the same answer: "That's the way it is! No filter! Buy one if you like!"
Upon getting a price quote for the filter here in NZ, the parts dept. called me back and mentioned that none of the Yaris models in NZ come with the filter. So from the dealer's standpoint, they're quite firm about not giving them out.
BTW, price for one shipped overnight = $60NZ ($42 USD)
Emailed my father to check the local Napa dealer in Canada. $20 cdn - I told him to buy 2 to bring over. Though they are not the Bosch or Purolator one, they said it was the equivalent replacement.
Super_BQ is offline   Reply With Quote
Old 03-31-2009, 08:38 PM   #9
buchieboy
Drives: Toyota Yaris
aside from the glove compartment? is there any other place where the cabin filter is located?
I cant remove my darn glovebox
buchieboy is offline   Reply With Quote
Old 03-31-2009, 09:00 PM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
pull up and the bottom will pop up and then slide the box down and it will come free.
unless yours is different
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
