Old 02-05-2019, 09:30 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Swap to EFI location complete.
New reading with MAF plugged in and after the ECU goes to sleep (about a minute):
30mA
Battery is reading 12.62V now and I decided to remove the tender. I'll let it sit for a few days, go back out and check voltage.
Once again, Trevor, thanks for this!
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2ZR MAF sensor connector info CrankyOldMan Yaris TS Talk 0 12-10-2018 03:05 PM
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 07:29 PM
