Old 04-14-2019, 01:56 PM   #1
komichal
Originally Posted by 2bz View Post
The lube used is GL4 75W. That's essentially the Toyota spec. Should be ok
You can find not just a few examples here in the forum where users used original Toyota oil and it solved their problem - despite the fact that the non-original oils they used before did meet Toyota specifications fully and their brand was sound.
Old 04-14-2019, 02:08 PM   #2
kivig
Drives: 2SZ-FE, 5MTM, 2008 TMMF
It's just that the mechanism of how the oil could fix things (by not being too thick) seems to be already there. But it is cheaper than a gearbox, so might be worth a try. Will check whether I can find original.
Edit: also it is likely that the oil I've already replaced was from factory...
kivig is offline   Reply With Quote
P0705: Yaris 2008 stuck in first gear in D position eepp DIY / Maintenance / Service 3 01-22-2018 11:24 AM
My Car Shakes Noticebly when I Put The Gear into Reverse When The Car Is on a Slope Meteorite2 DIY / Maintenance / Service 3 11-14-2014 05:56 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Reverse gear crunch Frankd1 DIY / Maintenance / Service 5 04-13-2009 12:43 PM
