2ZR swap. DO IT! Ask how!
I've always just run whatever was on the car for street use. I'm also not terribly competitive so I haven't refined my setup very well. That said, I did a track day weekend in my 1.8 swapped HB this weekend and put Hawk HPSs on my Corolla/SE front brakes. The difference between the generic street pads and the performance pads was incredible! There's lots of opinions on what brand/compound is best for any given application, so it may come down to trial and error on your end.
The bigger issue is that the stock 1.5 motor doesn't really have enough power to do point-and-shoot driving--you should be focused on momentum. Braking hard will (generally) give you slower times than carrying speed through corners. Getting the stickiest tires for your class will also help in that regard but costs more. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| Yaris 1.5 TS brake pads length issue | nikitas21 | DIY / Maintenance / Service | 0 | 08-12-2016 08:14 AM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| Light Rust or Grime on Brake Pads ? | YodaBird | DIY / Maintenance / Service | 15 | 10-22-2012 10:52 AM |
| New brake pads and noise | eii | DIY / Maintenance / Service | 8 | 06-25-2009 11:49 AM |
