![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Muffler replacement
A while back I bought a new muffier for Yaris. Amazon wharehouse deal $25 for a stainless walker . Plus $15 for donut gasket and fasteners .
Removing old muffler required long 14mm wrench and plenty of kroil penetrating oil.
Old muffler. Broke free with a Bergen long double box. Removed with SK G pro 14x15mm
Images of new muffler and hardware . Springs are to flex when going over bumps
The rubber hangers muffler hooks go ion.
View of walker muffler installed .view of joint
It’s hard to break nuts free on old muffler and hard to get old muffler off exhaust hangers . I sprayed silikroil penetrating oil on rubber hangers to get the metal rods out of rubber grommet .
Test to see if exhaust gas/water leaks from joint at start up . After pipes get hot sometimes leak seals. If leak tighten some more. It’s hard to tighten with the springs on bolts. That’s why long double box wrench is used.
Muffler used : Walker 54743 Quiet-Flow Stainless Steel Muffler Assembly https://www.amazon.com/dp/B007EJMLKM..._C3zhyhoGF9ZLL
Hardware : Walker 36454 Exhaust Spring Bolt Kit https://www.amazon.com/dp/B002VVJRDM...p_mob_ap_share
Donut gasket : Walker 31387 Hardware Gasket https://www.amazon.com/dp/B0015KZM2K...p_mob_ap_share
Factory muffler had nut built into muffler . Bolt threaded into muffler . New walker needed a separate nut. I held built in nut with socket or wrench (can’t remember ) and used long double box wrench on bolt for removal. Installing I held nut and tightened bolt against spring.
Not sure what you are trying to convey here. New gaskets need to get hot and melt slightly to completely seal the joint. Spring bolts purpose is to draw the flanges together as the gasket seats itself over time.
#14 |
It was so hard to pry muffler off rubber mounts that I bought this for next time . OEMTOOLS 25543 Exhaust Donut Stretcher https://www.amazon.com/dp/B004FEJIW8..._b-XVDb6VQWTYS
#15 |
That’s what happened it leaked slightly when cold but it did seal up nice later . Trying to convey if a nice amount of gas/water leaking out tighten it more.
#16 |
![]() ![]() ![]() ![]() Join Date: Feb 2010
I had the local shop replace my muffler with 2 different aftermarket mufflers. One was bouncing off the inside of the fenderd since it did not fit correctly The second one he tried just was not quiet. Drove me nuts! I ended up pulling it off my self and installed a genuine Toyota muffler. Now I am happy and learned a lesson regarding mufflers....did you learn anything me sharing this?
#17 | |
#18 |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
How does it sound compared to stock?
I'm a hermit named Lee |
| Exhaust leaking after replacing rear muffler | ThinkPad | DIY / Maintenance / Service | 13 | 08-19-2017 11:21 PM |
| rear muffler hanger broke | BobTheYaris | DIY / Maintenance / Service | 2 | 09-21-2016 05:59 PM |
| Muffler fell off, pipe size? | shepd | DIY / Maintenance / Service | 4 | 08-28-2016 09:01 PM |
| Bumper replacement | mchamp00 | DIY / Maintenance / Service | 0 | 07-03-2015 10:45 PM |
| Need Help to change Muffler | sobri46 | DIY / Maintenance / Service | 3 | 02-13-2014 12:42 AM |
