Old 12-23-2019, 05:54 PM   #1
CharlieBravo
CharlieBravo's Avatar
Drives: 2007 Yaris HB
UPDATE:
Everything put back together. Fluid re-added to transmission. I'm guessing its about 0.1qt less than whatever it had at the start. Little bit spilled out before I could put the pan in place when I pulled the axle out. Little bit leaked out as I was pouring it back into the transmission. There's probably a little bit still in the pan, funnel, and tubing.
Took it for a test drive. Nothing fell apart...yet. And the noise/vibration seems to be gone! The only thing I know for sure is that the passenger bearing was failing. Making a grinding noise when free spinning the wheel and noticed grease coming out of the bearing when I pulled it out of the hub.
I guess mission accomplished for now.....
CharlieBravo is offline   Reply With Quote
Mystery(misery?) vibration, I am determined to find a solution. seatech30 DIY / Maintenance / Service 4 06-16-2019 06:48 PM
Excessive vibration over 60mph. Suspension related? Aclosefriend Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-29-2016 06:06 PM
Vibration on idle & rough start Murtaza_murti DIY / Maintenance / Service 25 08-15-2015 12:58 PM
Yaris vibration abnormality talhahs DIY / Maintenance / Service 13 04-13-2013 10:07 PM
Pulsating Vibration dbudworth General Yaris / Vitz Discussion 5 03-28-2011 04:06 PM
