Old 01-14-2020, 09:16 AM   #1
mannycheckers
Drives: 2009 Yaris 2dr Liftback
Thanks for the tips yall. Now that I had a day away from the car and I'm not as frustrated, I'll give it another go with some vise grips. Also after talking with my buddy, he said to jack up the lower control arm to compress the spring slightly before trying to loosen the nut.
mannycheckers is offline   Reply With Quote
Old 01-14-2020, 01:18 PM   #2
tmontague
tmontague's Avatar
that is not a bad idea just be careful. I have done this a lot when torquing down suspension bushings where the car needs to be at normal ride height to do. I just use a jack under the ball joint to do this.
Keep in mind you generally will slightly bend your heat shield when doing this and if you don't bend it back you will get a terrible scrape noise upon your first test drive that will scare the crap out of you.
Old 01-19-2020, 11:05 PM   #3
mannycheckers
The deed is done. I finally got the front struts installed! I ended up picking up a Bauer 1/2 inch impact wrench from Harbor Freight because I already have the batteries, and it worked like a charm! I appreciate all of the advice from you guys, and couldn't have done it without your help. The car handles beautifully--stiffer but not bone rattling. These are excellent. Attached are the pics of the spoiler, the split bolt on the strut, and the car as it sits now.
Next up, I'm going to get new wheels and tires (thinking some Enkei RPF1s with 205/50R15 Continental Extreme Contacts). Also on my ever expanding to do list is power mirrors, foglights, DC exhaust header, Tanabe Medallion exhaust, TRD intake filter, vinyl wrap roof, sound deadening, auto dim rearview mirror, and a new head unit with backup camera. I'll try to keep you guys updated as I progress.
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
Yaris front strut install question PHXDEMON DIY / Maintenance / Service 20 07-10-2010 10:30 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
