![]() ![]() ![]() ![]() Join Date: Feb 2010
Bedding in brakes
We all know new brakes must go through the bedding in process. But I can't find any information regarding the affect bedding in if only one axle was done. In other words, if only the front brakes were replaced, will there be an adverse affect on the used rear brakes while bedding in the new front brakes? They get pretty hot.
No adverse affect.
Well ok then...now I know. Thank you. I'll do the front one weekend and rear two weeks later. Now I can take my wife for drive and when she asks where are going...we are going bedding in the Yaris!
While the bedding process is recommended, it is not something that would cause any harm if not done. When I bought my used Yaris, I asked the authorized dealer to change the brake pads and rotors since I needed it quickly. They did it and told me "just drive with this, brakes will have a bit different characteristics compared to what you were used to but it will all settle down in a few days".
That was eight years ago. Now - after 110,000 km - the brake pads look like they need replacing. Apparently the "do not care" approach worked. |
If you have the time and place to safely do it, do it. The average brake shop will not take the time to perform a bed in process on every job they undertake and for the most part performance is just fine. As optimal as it could be? No. I personally have noticed a difference between non-bedded and bedded brakes.
Bedding in is more about performance than longevity.
![]() ![]() Drives: 2008 HB Join Date: Dec 2012
Just equipped my car with new TRW pads and rotors. The only instruction from the manufacturer was to avoid heavy braking (if possible) during the first 200km.
Which is quite vague statement (You can drive 200km on a highway without braking) but it quite nicely illustrates what needs to be done for a "normal car" I use to drive around the block. :) |
| general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 03:20 PM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 01:04 AM |
