Old 05-04-2007, 08:13 PM   #1
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
My Yaris plans.. What do you think?
Bronze Rota Grids, Coil overs, shaved name badges (already done.) What do you think?
My photoshop work:
Before:
After:
Imagine is offline   Reply With Quote
Old 05-05-2007, 02:25 AM   #2
ChinoCharles
Drives: LB
Hellaflush Approved!
LOL that one was for you 03Z33.
Old 05-05-2007, 01:31 PM   #3
Imagine
Imagine's Avatar
Thanks guys..
Old 05-05-2007, 01:38 PM   #4
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
You are getting 17 inch Rota's correct? These photo shops look way to huge to me. I think if you go with the 17's it will look great. What coilovers are you getting?
SPONSORED BY
Old 05-06-2007, 05:07 PM   #5
Imagine
Imagine's Avatar
Yeah, the photochops look big.. I may not even go with a 17 inch. I personally like the 15/16 inch look better. We'll see though.
For coilovers I was thinking either the Tein or Megan's I'd have to do some more research before I decided. I'm still not sure, I have a while before I have to decide.
Old 05-06-2007, 05:27 PM   #6
brickhardmeat
Lonesome Cowboy
Yeah, i'm still on the fence on the Megan coilovers although it would be way nice I think I am sticking with the Tanabe DF since I can add a lot more to that than I could afford to with the coilovers. I am still trying to figure out how it would be "easy" to adjust them with that cowl covering the front strut tops. I am guessing anytime you wanted to change the settings you would have to pull everything off?
Yes, I am all for 15/16 inchers.
I have a set of JMAG in 15 and I think I'll purchase a set of Slips in 16 so I can switch from time to time.
SPONSORED BY
Old 05-07-2007, 12:01 AM   #7
Imagine
Imagine's Avatar
What cowl are you referring to? It would be gay to have coilovers if you have to remove everything to adjust them. I'd curtainly hope that isn't the case.
Got any pics of it with 15s and 16s?
Old 05-07-2007, 12:22 AM   #8
brickhardmeat
Lonesome Cowboy
There are lots of pics here with 15 and 16 inch wheels. Look at largeandinfront's car to see a 16 inch wheel set up with a similar drop.
Open your hood and look at how the strut tops are covered by that cowl. The cowl, I think, would have to come off to adjust the fronts. You could probably do it fine with a little mirror something. It would still be cool to go down about 2 1/2 or 3 full inches but I'm scrapin' at two in the front so I dunno how cool I think it would be really driving my car on these crappy Dallas streets that low.
SPONSORED BY
Old 05-07-2007, 12:34 AM   #9
Imagine
Imagine's Avatar
Oh! Height adjustments would be done from under the car. Just jack up the car and use the spanner wrench to thread up and down. The compression/rebound adjustments might be a different story though. I'll have to look, I haven't spent a whole lot of time under the hood yet. I picked it up wednesday, and haven't stopped driving it yet.
Going down that low would definitely be a trick, you'd have to go with taller wheels to give yourself more ground clearance.. Then you may have fender clearance issues.
Old 05-07-2007, 12:40 AM   #10
Black Yaris
der Zeck
Black Yaris's Avatar
More and more Ohio ppl
Old 05-07-2007, 12:51 AM   #11
brickhardmeat
Lonesome Cowboy
Cool, I've never had or even seen coilovers up close in person obviously. I guess the strut top dial thing is just for dampening. hmmm, guess I'll have to keep thinking on those but I already have DF210
SPONSORED BY
Old 05-07-2007, 02:30 AM   #12
YogiYaris
Drives: Blue 2007 Toyota Yaris
Yeah man that will look good, but I would personally stick with 15 inch wheels seeing as how the car comes with 14 inch wheels stock. Not to mention the car doesn't even make 100hp so you will have better performance with 15s.
YogiYaris is offline   Reply With Quote
Old 05-07-2007, 10:32 AM   #13
Imagine
Imagine's Avatar
My car came with 15s, but you are right about the weight and performance. I ran 205/40-17 and 225/50-15s on my civic when I was rocking wheels and you could definitely tell a difference, not to mention 15s are a little more forgiving for rough roads. Which I have plenty of around here. Id never run anything under a 45 series tire again.
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
