Old 07-15-2020, 02:23 PM   #4
RedRide
RedRide's Avatar
If you are only replacing 2 tyres, then the new ones go in the rear. It doesn't matter if the car is front wheel drive or rear wheel drive.
I believe that is correct.
In e case of a blow out at higher speeds in the front, you can usually recover without a serious incident. .
However, if a rear blows out, at higher speeds, it can potentially be quite dangerous .
DF210 Front NF210 rear? gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-13-2010 12:15 PM
F/S: Front and rear tow hook. Mister Z Items for Sale by private party 5 05-04-2010 01:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
