Old 07-17-2020, 06:25 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Where on the car are those tubes? Are they from the top of the engine, attached to the head? The Auto trans cooler is just in the bottom of the rad with rubber inlet and outlet hoses. Is that tubing part of the throttle body heater/cooling circuit? The other aluminum tubing on top of the engine is for vacuum to the brake booster, afaik.
Old 07-18-2020, 04:34 PM   #2
Basmii
Drives: 09 yaris hb
Its the one that feeds the heater hose/throttle body. It runs across the trans side of the motor.
Basmii is offline   Reply With Quote
Old 07-18-2020, 04:40 PM   #3
Basmii
Drives: 09 yaris hb
Pic of the XD tube installed.
Old 10-26-2020, 11:16 PM   #4
Basmii
Drives: 09 yaris hb
This project had to take a back seat to work stuff for a bit but I managed to get it the swap done this weekend. If you disassemble the front end of the car getting the old motor out is not a big deal. I left the short driver's side axle attached to the transmission until it was out because there is not a lot of clearance to a prybar on it under the car. Beyond that I don't think I did anything different than the others on here..
Old 10-26-2020, 11:20 PM   #5
Basmii
Drives: 09 yaris hb
Speedometer wires from the old harness.
Old 10-26-2020, 11:23 PM   #6
Basmii
Drives: 09 yaris hb
Pink black and white
Old 10-26-2020, 11:28 PM   #7
Basmii
Drives: 09 yaris hb
New engine in without issue.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
THE 2ZRFE engine swap thread - Just the facts brushforhire Performance Modifications 40 12-25-2019 12:08 AM
2zrfe Engine swap - $500 picked up brushforhire Items for Sale by private party 0 03-17-2017 11:21 AM
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 10:43 PM
