Old 07-20-2020, 09:20 AM   #1
stidnam
Drives: Starlet
I think you're going to need a 17mm offset spanner regardless.
https://youtu.be/sryKfs1JwCs?t=190
stidnam is offline   Reply With Quote
Old 07-20-2020, 10:41 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, couldn't find a 17mm but a 11/16 worked great. I didn't realize that I have to remove the coil spring nut to get the mounts out. Dang! Now I have to go find a spring compressor or order new mounts. EDIT: I just ordered 2 new mounts. They'll be in tomorrow morning. May as well leave the stock struts intact. That way if I hate the coilovers, I can go back to stock.
Upper mount removal
Lower Strut bolt removal. God love Toyota for putting anti-seize on these big bolts!
Strut out
Driver's strut out
Every bolt and nut gets wire brushed and anti-seize applied. Clearly, I have some time while I wait for my new upper strut mounts to arrive. They will be in at 8:00am tomorrow.
I degreased, sanded primed and painted the end links. They'll get sprayed with thick rustproofing after installation. Which reminds me, I have to pick up the recommended marine grease to apply to the threaded bodies of the coilovers. Shouldn't be a problem as I live in a fishing community.
WTB Coilovers or lowering springs and rear sway bar 07liftback Willing to Buy by private party 0 08-18-2017 02:14 AM
Want to trade Subs with amp and tein stech springs for coilovers! NaviLupets Willing to Buy by private party 0 11-05-2013 11:36 PM
lowering springs + adjustable coilovers Golddeenoh Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 05-20-2013 10:36 AM
FT: Tokico Blues + Tein S Tech Springs for Coilovers Plus Cash DeathBeard Items for Sale by private party 0 11-02-2012 04:01 PM
New springs for Megan coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-10-2010 08:59 PM
