Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Rocky Mountains / Great Plains
Old 09-15-2020, 09:28 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've had issues with mine ever since I took the front end apart to swap the engine, still haven't resolved it.
The horn relay is part of the big black fuse/relay device in the engine bay fuse box. Real pain to test that one because the pins are tiny and underneath the fuse block.
The horn earth/ground is connected directly to the unibody. If there isn't adequate continuity between the horn body and the battery through all the bolted connections, it won't work.
Tags
electrical, horn, relay
DIY aftermarket steering wheel install with horn and airbag delete tmontague Performance Modifications 19 11-30-2018 01:19 PM
Horn Not Working nacer DIY / Maintenance / Service 5 07-25-2014 09:57 AM
Help! Turn Signals and Horn Stopped working kashanf DIY / Maintenance / Service 3 05-28-2014 06:20 PM
Problems after horn install Astroman DIY / Maintenance / Service 14 04-07-2014 06:15 PM
Wireless key entry stopped working modmonster DIY / Maintenance / Service 9 03-31-2014 12:34 PM
