Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-05-2020, 10:22 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's doable at home. I had to drop the passenger side engine mount to get enough clearance and ended up taking off the bumper cover, headlight, fender liner and filler panel next to the radiator to have enough access for my impact wrench. It's a rubber gasket so it's not terrible to take it off and put the new one back on.
Old 10-05-2020, 04:30 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks Sam. Great to know that the engine doesn't have to come out to do it, lol. So, I'm guessing a couple inch drop would be needed to clear the bottom of the frame? Just pop a jack and wood block under the engine, I suppose.
2007 - Water pump suggestions littleblackyaris DIY / Maintenance / Service 1 10-04-2020 08:51 AM
Why the water pump went on my 2009 a theory bronsin General Yaris / Vitz Discussion 19 08-06-2018 12:45 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
