Old 10-24-2020, 08:43 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Pinchlite View Post
I would imagine opening rear lights would be the same as opening any other plastic headlight assembly>
I want to open the tails and install flexible led tubes for this effect...
https://i.imgur.com/wh8QgZi.jpg
I already opened up the spec D and replaced the Halos so I am quite confident I can do the rears.
I was just curious if they might be permanently glued vs Butyl?
Pic of my diy specd halo upgrade.
https://i.imgur.com/dPfU9hA.jpg
Can't help you with the taillights, but I do have a couple questions about the SpecD headlights. Why did you upgrade the halos? Are the ones in the SpecD lights poor quality? How is the overall lighting at night with the SpecDs? I've not had good luck at all with any aftermerket headlights. The light patterns and visible have been horrible; one swap out rendered a van I had undriveable at night.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 11:14 PM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-21-2012 12:25 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 10:24 AM
