Old 03-14-2021, 04:22 AM   #1
koos
Drives: toyota yaris 2007
Toyota Yaris tial light problem
Hi Guys,
I recently bought a Toyota Yaris 2007 model and the car is amazing but there is a slight problem the light that is suppose to switch on (in the tail light) when I switch on my head lights does not come on .
I have checked the fuses (non blown)
took the multi meter and there is no power at that section of the tail light
can you please assist me ?
(the break and turning light in the tail light works)
koos is offline   Reply With Quote
Old 03-18-2021, 11:32 AM   #2
Neinris
Originally Posted by koos View Post
Hi Guys,
Try checking for ground on both sides of the socket, one side to ground and then the other, I believe one side should be grounded, if both don't have ground then it's bad, if both have ground then it's bad. Might need to hand to hand trace the cable to see if there's any damage.
Good luck!
Old 03-07-2022, 05:37 AM   #3
maugustine
Drives: Toyota Yaris
Tail light problem
Hi
One thing that solved my problem was cleaning the switch contacts. https://www.youtube.com/watch?v=rsucNoZsAyI
maugustine is offline   Reply With Quote
Old 03-08-2022, 06:28 AM   #4
IndestructibleYaris
Not having dual filament bulbs will sometimes do this, in case someone is suspicious of that
IndestructibleYaris is offline   Reply With Quote
Tags
problem, taillight, toyota yaris 2007, wiring harness
2020 Toyota Yaris – first compact TNGA-based model; Dynamic Force engines, Advanced P toyotavios_11 Third Gen Yaris General Discussion 16 11-02-2019 06:45 AM
2008 Toyota Yaris airbag light ON Temeku DIY / Maintenance / Service 0 10-23-2016 07:16 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
