Old 04-17-2021, 02:23 PM   #1
speedworxs
Drives: |Mr2
i'm picking up a 05 hatchback , i was intending on this very swap.
not as electrically smart for the electric pump, but i was debating some cams (254) with it too. i wouldn't go for the itb's but might do a corolla throttle.
will the factory ecu run fine with the increase in compression? i wish there was a way to increase rev limit
speedworxs is offline   Reply With Quote
Old 04-17-2021, 07:48 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
You can increase the rev limiter if you overclock the factory ECU, but you have to be careful, too much will give you serious problems. But that is one "ghetto" way of doing it. Of course, a proper piggyback or standalone is a far better route.
Premium will be a must at minimum with that kind of compression and stock timing.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
prius c 1nz swap Zedicus Performance Modifications 33 03-29-2025 12:44 PM
Prius Piston swap in 1NZ (update pls) rabbito Performance Modifications 2 06-12-2016 10:18 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
