#1 | |
![]() ![]() Drives: 2NZ ITB NCP10 Join Date: Dec 2020
If so: -No rev limiter currently. Until I've got some stronger rods I'll likely set the rev limiter somewhere around 8200-8300rpm. And yes in this case, swapping to the C56 gearbox is an absolutely magical upgrade. Having the 4.3 final drive instead of the 3.5 makes the whole thing so much better. I'd not be suprised if my 1300cc motor would have been into the 15 second quarter mile range with the C56 box. The individual ratios of the C56 are most excellent. On the shift from 2nd to 3rd, shifting at ~8800rpm it drops down to only around 6500rpm on gear change. So it stays in the powerband awesomely. sdfhjkj.jpg As for the purpose of this car, it's not a daily driver anymore as I've got a work car. But it still returns fairly decent milage, the high compression actually makes it decently economical. I've been getting somewhere around 5.5-6 litres per 100km. So thats somewhere around 40mpg. I could still get it a little better with optimizing the ignition timing further, will get there eventually. |
#2 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I wish I know how to tune the ECM, because I have another "Frankenstein" in mind. Last edited by Neinris; 07-20-2021 at 11:35 AM. |
#3 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
The 2nd and 3rd gen Yaris have the slightly better ratio'd C50 with the 3.72FD. I wouldn't even waste my time with swapping in a better FD into a C50 gearset. They're still very much an economy transmission.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
#4 | |
#5 | |
Speaking of which, I've just finished fitting an AE111 torsen into my spare one. I'll be honest it battled me all of the way haha. But I'm glad it's done now, cant wait to see how it performs with an LSD! Had a few headaches including forgetting to put the speedo drive gear on before pressing the new bearing on... ![]() gearbox.jpg Some other issues, half way through the run of NCP13 boxes they changed a bearing and shim on one side of the diff head. So AE111 and early NCP13 have same bearing and shim (19.4mm bearing) Then late NCP13 and NCP91 have a different bearing and shim. 18.5mm and thicker shim) So this box turned out to be an early one, but I ordered the late bearing. So I pulled apart my 2004 C152 and it had the correct shim to make the new bearing work. Probably about 10-12 hours total work, lots of mucking around. But I could do one much quicker next time. |
| prius c 1nz swap | Zedicus | Performance Modifications | 33 | 03-29-2025 12:44 PM |
| Prius Piston swap in 1NZ (update pls) | rabbito | Performance Modifications | 2 | 06-12-2016 10:18 PM |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
| Toyota says don't call them Priuses -- call 'em the Prii | Kal-El | Off-topic / Other Cars / Everything else Discussions | 7 | 02-22-2011 10:30 AM |
