![]() Drives: Toyota Yaris Hybrid Join Date: Dec 2021
Light sensor but no auto lights
Hello there! Cit.
I have the Toyota Yaris Hybrid Active 2018 with light sensor under the windscreen, but I don't have the 'Auto' mode in lights lever (I have the Auto High Beam). If I buy the light switch lever with 'Auto', will it works? I also bought the Cruise Control lever and installed it, the car doesn't have that OEM, but with 20€ now it works without problems! Thanks :) |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
It's going to depend on whether your body control module supports automatic headlights. The sensor goes to the body control module as does the auto switch wiring on the headlight stalk. If your car has all that wiring and the body control module supports auto headlights, then I reckon you'd be in luck.
#3 | |
Option 1: Hook the switch up and see if it works. Option 2: Compare the part numbers of body control modules to see if they differ and get the wiring diagrams to start tracing and testing the circuits
option 1 is not possible because I don't have the switch now
for option 2 how do i check part numbers and control modules? |
Do you have a VIN number for a car with the auto headlights? - toyodiy.com
What's the part number of the light sensor/wiring diagrams? That's my Toyota:
https://www.toyodiy.com/parts/g_E_20...-CHXNBW_4.html |
I checked this parts in WIRED panel.
My Toyota Yaris Active with light sensor but not the auto switcher: 82141 WIRE, INSTRUMENT PANEL 82145-0U670 PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82145-0U680 PRE-COLLISION SYSTEM-WITHOUT&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82145-0UA30 PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) 82145-0UA40 PRE-COLLISION SYSTEM-WITHOUT&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) 82146-0UP10 PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82146-0UP20 PRE-COLLISION SYSTEM-WITHOUT&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82146-0UP40 PRE-COLLISION SYSTEM-WITHOUT 82146-0UP50 82146-0UP60 PRE-COLLISION SYSTEM-WITHOUT&WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START) 82146-0UP70 WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START) 82146-0UP80 WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE&AUDIO-*DA & *BT & 8SPEAKER 82146-0UQ50 OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82146-0UQ60 WIRELESS DOOR LOCK-WITH(SMART KEY & PUSH START)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82142A WIRE, INSTRUMENT PANEL, NO.2 82140-0D050 And here the Yaris Style with light sensor and auto switcher: 82141 WIRE, INSTRUMENT PANEL 82145-0U670 PRE-COLLISION SYSTEM-WITHOUT&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82145-0UA30 PRE-COLLISION SYSTEM-WITHOUT&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) 82146-0UP10 PRE-COLLISION SYSTEM-WITHOUT&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82146-0UP60 PRE-COLLISION SYSTEM-WITHOUT 82146-0UP70 82146-0UP80 LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME)&OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE&AUDIO-*DA & *BT & 8SPEAKER 82146-0UQ60 OUTSIDE REAR VIEW MIRROR-AUTOMATIC RETRACTABLE 82142A WIRE, INSTRUMENT PANEL, NO.2 82140-0D050 I have all the codes that are on the Yaris Style, right? So...the idea can works! PS: I don't have the mirror-automatic retractable, so I have the cable drive but not the motordrive or the button inside the car...
And also my Yaris Active has:
84140 SWITCH ASSY, HEADLAMP DIMMER 84140-0D270 84140-0D300 FRONT FOG LAMP-WITH & W(RADIATOR LOWER GRILLE=PAINTED) 84140-0D310 FRONT FOG LAMP-WITH & W(RADIATOR LOWER GRILLE=PAINTED)&LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) 84140-0D320 LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) The other Yaris Style has: 84140 SWITCH ASSY, HEADLAMP DIMMER 84140-0D300 84140-0D310 LIGHT CONTROL SYSTEM-WITH(*ALC & AUTO OFF & FOLLOW ME HOME) Well.....that's good |
It works perfectly!
I received two pm but I don't know if the system sent them correctly....so:
the item to buy is this 84140-0D310 like here: https://www.autodemolizionegualtieri...view&id=179012 with the 'AUTO' signature on the light switcher Second: follow the steps in this video https://www.youtube.com/watch?v=MugS...ALP2Xw&index=5 if doesn't work, the car doesn't have the correct wiring, my Yaris is an 'Active' one, but now is like a 'Trend' one with cruise control, auto lights and auto folding mirrors installed :D |
Drives: Yaris Hybrid 2018 Join Date: Jan 2023
![]() Drives: 2018 Yaris Hybrid Feel Join Date: Apr 2023
Hey vins. I have a 2018 hybrid feel in Spain that has auto high beams but not auto lights. You think I could do the same? Also, what did you use to get the auto folding mirrors. I’d be interested in that too. Thanks.
| DIY - Exterior lights on when doors are remotely unlocked | CTScott | DIY / Maintenance / Service | 21 | 07-31-2025 07:30 PM |
| Tail lights - switch brake light with parking light | davidlipski | Cosmetic Modifications (Exterior/Interior) | 0 | 06-05-2016 10:34 AM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 11:14 PM |
| Add auto on/off lights + fog lights using OEM switch inquiry? | ricepower | DIY / Maintenance / Service | 4 | 04-05-2011 05:46 PM |
