Old 04-17-2022, 12:59 PM   #5
IronYaris
Drives: 2008 Yaris 3dr
Originally Posted by sven337 View Post
Hello,
I'm making this post to report on my attempts, so that people who have the same purpose do not waste too long.
Introduction
I have a 2006 (?) french Yaris with a W58824 head unit (radio, CD player with MP3, no USB host, no aux input). This device is special in that unlike the american Yaris many people here report about, it doesn't have an analog AUX input, nor an AUX button on front.
I have, naturally, attempted to plug a jack on the D74 connector, using the pinout described in the Yaris repair manuals available from a thread on this forum. I confirm it doesn't work. The pins are actually reused for other things in my Yaris.
So what are the remaining options?
1-emulate a CD changer
2-inject AUX input at CD reader output
3-inject AUX input directly at amplifier input
1) is harder than it seems because this unit uses AVC-LAN, so you need some electronics to make it think there is a CD changer. Refer to http://www.softservice.com.pl/corolla/avc/avclan.php for details. Although my skills would enable me to do that, I was looking for a simpler and less expensive solution. An AUX input isn't that great as compared to just plugging a USB thumb drive with MP3s, so that isn't worth a lot of time nor money to me.
2) and 3) require dissassembling the unit, and I thought I would report about that - and my subsequent failures at both options - so that other can take it from there.
Disassembling the device
To disassemble the device, after you've taken it out of the car, you need to:
- remove the black ventilation "tunnels", which are clipped to the plastic front of the W58824 by 3 clips on top and 3 at the bottom. You have to lift very carefully the bottom ones first, then pull on the front a little to free the 3 top clips.
- remove the front of the unit. This is by far the most difficult step. The front uses those annoying hard plastic clips that tend to break if you look at them the wrong way. There is NO screw to take off, it's just the clips that hold the plastic front to the metal frame! Very carefully, free them one by one. I had to get help from another person to simultaneously pull on the metal frame. You can pull with quite some strength without risk.
- remove all screws you can see :) and try to remember where they go. The unit is made of a mainboard and a separate CD player. Its design is actually quite similar to that of another Panasonic unit, CQ-TS7471A. The repair manual of that unit is available on the Internet (link : http://www.s-manuals.com/pdf/car_aud...ice_manual.pdf) and will help us for the electronics part.
- pay attention to the ribbon cable between the CD player and the mainboard! It is accessed by removing a small metal plate on the side of the unit. Remove it before completely separating the boards and starting to look at them. I tore it a little bit, without any adverse impact, but play it safe and remove it first.
Electronics
Unfortunately, it seems that most of the chips present on both boards are either internal Panasonic components, or very confidential designs, as I was able to find practically no datasheet on the Internet!
That's where the repair manual helps you - the chips are different, but some of the names, and the general architecture, are identical.
One difference I am aware of is that the CQ-TS0570LC (Panasonic's name for the W58824 unit we're looking at) has MP3-data-CD ability, which the CQ-TS7471 doesn't have. I have not been able to find out which chip was responsible for decoding the MP3. I would expect the main DSP on the mainboard to take care of it, but the 14-pin interface between the CD reader and the motherboard hasn't changed from the CQ-TS0570LC.
Perhaps the "serial data" pins are used to transfer the mp3 contents, I am not sure and it's not something we care about for this little project.
CD reader output
The CD reader connector has fourteen pins, of which three pins are interesting - Left, AGND, Right. Identify them - refer to the repair manual linked above. On the mainboard - sorry I don't have pictures - they are the three top pins of the connector, next to each other. On the other side of the connector is a +8V power supply, with a trace which is physically a little further away, and a capacitor next to it. You don't want to get the connections wrong. :)
So you can hook up your jack connector there, that's what I did. You have tiny vias for all of those pins, if you have wire that is thin enough (I used single strands of copper wire). Good luck soldering them, too. I destroyed part of a trace, without any impact on functionality. Still, you have to be confident in your abilities because this is tiny.
The problem I had was that it didn't work. When I plugged the jack connector (I used a male cable instead of the more common female sockets people use for AUX inputs) into the MP3 player, the sound from the currently playing CD was completely muted (overpowered?), but I didn't hear anything from the MP3 player. Note that I neglected to put small capacitors in series with the jack connector. This may or may not explain things. I was quite tired by the time I tested, and don't have an oscilloscope available, so I couldn't easily check.
Amplifier input
The amplifier is pretty easy to identify on the mainboard. If you can't spot it within 15 seconds, please reassemble everything and gain more experience before you mod a car radio. Mistakes are expensive here.
The center pins have four easy to notice tiny traces, with a slightly bigger one in the middle. Those are the FL/FR/RL/RR and GND traces. You can identify them easily since the other pins of the amplifier are outputs and consequently have larger amounts of copper to them. You can attempt to plug your jack connector there.
The problem I had was that it didn't work either. Again, the signal would be muted (overpowered?), but it's not like I heard anything from my MP3 player either. Do note, again, that I didn't have capacitors in place, and also as I realized later this unit uses a small preamplifier. For all I know the signals levels were completely wrong.
Future work
I'm giving up on 2) and 3). The connections are hard to make, and my attempts didn't work. An AUX connector is just not worth more than the 7-and-a-half hours I spent on this small project.
A second try on the CD reader might be interesting. Hooking up to the preamplifier sounds like a workable idea as well.
You may want to try injecting the signal at the radio's output, but I'm not sure it would make any difference.
oops wrong thread
IronYaris is offline   Reply With Quote
aux, jack, w58824
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
AUX connector for Yaris 2006 quemaculo In Car Entertainment + Electronics (audio / video / alarm) 1 08-27-2006 09:14 PM
