Old 12-28-2022, 04:05 PM   #1
sh0rtlife
Originally Posted by jack black View Post
Merry Christmas to you all.
I inspected the new belt closely while doing maintenance (oil and ATF change, tire rotation, battery check, and other visual checks). the new belt is good quality: Gates Micro-V and in a great shape. the harmonic balancer is not wobbly and none of the pulleys look misaligned.
the only thing that caught my sight is the water pump pulley is partially smooth and polished and in small part rusty. now, i remember it being more rusty 6 months before with the old belt. i have no idea if it maters. i'll take a picture if i can.
i noticed coolant a bit on a low side, i hope it's not headgasket from the overheating episode.
Thanks everyone!
a weaping water pump due to an over tight belt trashing the bearings in the pump is a possibility...
and the water pump pulley should be 100% polished looking..unless the car has been sitting a while..the belt should keep it polished
Old 12-30-2022, 01:42 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
when the kid was in a school overseas, the car sat for a couple of years with only occasional use (but battery was kept charged religiously). But that changed when she came back in 2021 and she made about 15,000 miles since.
jack black is offline   Reply With Quote
Old 12-30-2022, 02:54 PM   #3
sh0rtlife
thats why you have some rust spots on the pully they will go away and are nothing to be concerned about...the "sitting" caused the exposed section of the pully to get a bit of surface rust no big deal
Brand new belt is squeeling RMcG DIY / Maintenance / Service 17 06-25-2018 01:37 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Drive belt squeal at idle. junorico24 DIY / Maintenance / Service 22 03-29-2013 09:27 PM
Altenator Belt Broken After Replaced by Toyota Yaris_guy DIY / Maintenance / Service 12 01-18-2011 09:14 PM
