01-05-2023, 02:03 PM | #19 |
Never have I seen that happen. Hang around here long enough and you get to see and hear it all.
Damn good thing you found that piece. Getting it back on and locked down tight will definitely solve the initial purpose of this thread.
01-05-2023, 08:00 PM | #20 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
it begs the question tho....how in the hell did it work loose?!?!?!?!
01-06-2023, 01:40 AM | #21 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
lol what the hell? the ac compressor pulley flew off?
01-06-2023, 02:59 AM | #22 | |
Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
make sure you check the water pump and ac bearings for wobble in case those need replacing too as they were taking a beating while the belt wobbled. |
01-06-2023, 03:29 AM | #23 |
01-06-2023, 12:23 PM | #24 |
Drives: 2007 4dr sedan Join Date: Jun 2009
Mine did the same at about 18 monts old. I found it laying on the bottom cover and screwed it back on the compressor. That lasted about 10 minutes. Took it to the dealer and they replaced the compressor under warranty. I wasn't happy as I thought some Loctite would solve the problem without disturbing the line set of the compressor which could create future problems.
They insisted so I let them do it and have had no problems since. I am convinced it was a manufacturing defect in that no Loctite was applied from the parts factory. |
01-07-2023, 11:31 PM | #25 |
Drives: 2007 red Yaris HB AT Join Date: Dec 2013
this is all very weird indeed. i guess it must have unscrewed itself?
i'll try to fix it all the next time i see her. thank you all for helping! |
03-30-2023, 11:16 PM | #26 |
here is an update. after i screwed it on, she left the town and reported no problems with the belt. she came back 4000 miles later and the part is laying in the bottom of the engine compartment again. when you screw it in back, the threaded thing in the middle of the AC pulley just rotates freely with no resistance. so, the part cannot be attached securely and it will get unscrewed again by itself. I have no clue how it works and what is broken. see the picture of the AC pulley and the threaded thing in the middle.
Thanks! Edit: I found a related thread here: https://www.yarisworld.com/forums/sh...ad.php?t=42290 Last edited by jack black; 03-30-2023 at 11:44 PM. Reason: added a link |
04-02-2023, 06:46 PM | #27 |
Now I suspect it's the AC that is at fault and locks intermittently, tearing the belt. I'll tell my kid to have the compressor looked at. It's probably $$$$.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Brand new belt is squeeling | RMcG | DIY / Maintenance / Service | 17 | 06-25-2018 01:37 PM |
DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 10:41 AM |
Drive belt squeal at idle. | junorico24 | DIY / Maintenance / Service | 22 | 03-29-2013 09:27 PM |
Altenator Belt Broken After Replaced by Toyota | Yaris_guy | DIY / Maintenance / Service | 12 | 01-18-2011 09:14 PM |
