Old 02-12-2023, 01:31 AM   #1
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
huh, I didn't realize the manifolds were different.
the USDM 1NZ one is 17101-21080 while the "RS" manifold is 17101-21070. Guess its time to go on beforward and grab one off a Toyota Ractis or Vitz RS lol. I already have a second gen Ractis cluster in my 2014, may as well run a Ractis manifold too
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 02-12-2023, 05:35 AM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
Have you already done the 1zz-fe throttle body and injector swap?
Compeer is offline   Reply With Quote
Old 02-12-2023, 04:21 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
No. Stock injectors and TB, the throttle response doesn't bother me after I swapped in the Lexus IS250 pedal that gets rid of the dead spot and makes the pedal heavier feeling.
2014 NCP131 5 Speed
Old 02-12-2023, 05:01 PM   #4
Neinris
Drives: 08 Yaris 3 Door Hatchback
I've thought of doing the pedal swap in the future. Would you share how you mounted the pedal? Did you make an adaptor plate?
Neinris is offline   Reply With Quote
Old 02-13-2023, 07:33 AM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
The gen 3 Vitz RS has its own OEM pedal bracket so I just ordered one from RHDJapan. I don't know if it will work in a 2nd gen though.
Part number is 78114-52020.
2014 NCP131 5 Speed
Old 02-13-2023, 02:59 PM   #6
Neinris
Thanks! Does it look like something like this? If so, did it feel weird that the pedal moved forward? The second and third gen's throttle pedals are the same btw.
Old 02-13-2023, 09:25 PM   #7
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Sort of, its metal though and raises the pedal up about an inch which makes it almost level with the brake and clutch, makes heel-toe a breeze. The Lexus pedal I pulled out of the junkyard had that spacer, I didn't end up using it though and threw it out.
2014 NCP131 5 Speed
Old 05-16-2023, 05:46 PM   #8
ElMagnifico
Drives: 2012 Sedan
Part number for pedal?
ElMagnifico is offline   Reply With Quote
Old 05-22-2023, 12:15 AM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
78110-53120
It will either require a Japan market Vitz NCP131 pedal bracket to work OR you can fab up something yourself. Electrically it is plug and play.
2014 NCP131 5 Speed
Old 05-26-2023, 05:57 PM   #10
Neinris
78110-53120
Mitch, do you still have the 1ZZ TB installed? If so, did the pedal reduced/eliminated the rev hang?
Old 05-26-2023, 08:59 PM   #11
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Nope, stock TB. I have a port matched 1NZ manifold + 1ZZ TB sitting in my shed, never could get it to play nice with my car so its shelved for the time being. Lots of life events happening, so.
To answer your question; no it didn't change the rev hang. It just made the pedal even with the brake for easy heel toe downshifts and made the pedal heavier which I find much easier to modulate. It also eliminated that annoying dead spot the stock pedals have.
2014 NCP131 5 Speed
1ZZfe mod info darkMINI Performance Modifications 21 07-12-2011 11:41 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
