#1 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Nice so the bolt i didnt know I had to move and the hose I had realized was going to need modified, Right now im pretty happy with how the long set up is performing but will in the future try that, did you notice any difference? Last edited by Compeer; 03-20-2023 at 03:08 PM. |
#2 | |
but on dyno, my peak torque shifts 300rpm higher with stock manifold, the torque drop 25% between peak torque and torque at rev limiter with RS manifold, the torque drop 19% between peak torque and torque and limiter |
#3 | |
Need to dyno my car to find out and won't do that till i have a tune for it. Going to get a trd cap and leave it upside down just for remcafe! lmfao |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
It is! Its crazy torque down low now with the other mods Ive done, very very easy to loose traction now in 2nd and in the wet in most gears lol.
I haven't been active for a while because the car currently is just damn fun to drive, the Throttle body change, intake runner spacer, intake tube and airbox mod are just working so damn well. The car has no dead spot any more and will DURTTTTT all the way from 1.8krpm..give her the beans and it lights up till red line. With only 6400rpm max it feels like I never get off the torque curve. I dont think I will change the manifold to the shorter one as currently she destroys the tires in 1st and 2nd gear and feels like you are actually driving a hot hatch. Last edited by Compeer; 07-15-2023 at 04:25 AM. |
#6 | |
Its the EGR plate that I used JB weld on to seal the holes on. where ever you find the shorter manifold you find the egr plate, it bolts on to our block normally, just means you have to loose the top engine cover.
| 1ZZfe mod info | darkMINI | Performance Modifications | 21 | 07-13-2011 12:41 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 08:15 PM |
