Old 08-01-2023, 07:18 PM   #1
sh0rtlife
torching the connections is NOT required...to be honest the best thing you can do is dissconnect EVERY joint
idealy get some kroil and spray all of the joints and re-spray them every day for a week, after that TIGHTEN everything just a tiny bit before you try and loosen and they should all break free
if your dead set on torching, just get them a little hot and kroil em hot as it makes the kroil wick into the threads
Alternative rear disc conversion? Neinris Performance Modifications 132 06-18-2024 09:03 AM
Brake caliper rewind tool for rear brake piston Mightymoo DIY / Maintenance / Service 12 05-08-2023 11:07 AM
Need rear brake help! Star wheel/spring combo won't reattach msapocalypse DIY / Maintenance / Service 0 10-08-2016 06:19 PM
Rear brake disks sliding bolt torque Keymaster DIY / Maintenance / Service 6 04-12-2016 03:53 AM
