![]() Drives: Toyota Yaris 2007 1krfe Join Date: Sep 2023
I have a European Toyota yaris 2 from 2007, with a 1.0 1krfe engine with p0420 error.. I purchased an extension to remove the oxygen probe downstream of the catalytic converter, but the error appears again... Currently the probe values are between 0.1 and 0.85volts... I think that sometimes it exceeds this and the error appears.. I would like to modify the electrical wiring of the probe with the electrical filter, so as to always have volts values in the suitable range but I found various information on the net. Do you have the wiring diagram compatible with Toyota Yaris? Thank you
I apologize if I post another site, thanking you but I found this one which can be useful, however they are two different circuits
get a longer tube version with a "mini cat" in the tube..should solve the issue...if it doesn youve got engine issues
Thread Tools | |
Display Modes | |
VVT Oil Control Valve Filter Replacement (the other oil filter) | 2bz | DIY / Maintenance / Service | 4 | 02-10-2019 01:34 PM |
Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
Car shuts off when A/C turned on... | Howster | DIY / Maintenance / Service | 33 | 07-06-2013 05:00 PM |
Beware WIX Filter #51394 | zkay | DIY / Maintenance / Service | 19 | 12-22-2012 12:09 AM |
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
