Old 11-01-2023, 06:27 AM   #3
Calrenman
Drives: 2015 Toyota Yaris LE Hatchie
I put a set of Yokohama 195/60/15 YK-GTX all season tires on my 2015. They are (~3mm).2 inches taller and (~13mm) 1 inch wider than stock. I have a rear sway bar (TRD) and a sub frame brace (Cusco) under the engine. I run 37psi on the front and rear. I have never broken the car loose and I like to push it in the corners in the local canyons. Traction at that pressure will suffer. Milage will increase. Always check tire manufacturer specs and mind them.
The stock tire loading chart is "saying" if you carry more weight put more pressure in the tires Less weight slightly less pressure.
Calrenman is offline   Reply With Quote
pressure, tyre
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
