#253 |
![]() ![]() ![]() ![]() Join Date: Feb 2010
Just hit 200,000 on my 2010 today. Runs like the day a i purchased it new and still has no rattles etc.
#254 |
Drives: 2008 Sedan Join Date: Apr 2022
188,888miles here on my 2008 Yaris Sedan. The water cooler went out and was replaced under warranty. Around 160k miles the clutch went out I had it replaced it drives like new. I look forward to joining the 200k miles club soon.
#255 |
![]() Drives: 2010 yaris 4 door hatchback Join Date: Apr 2020
Just turned 350000 tonight! 2010 yaris 4 door hatch with 5 speed. Still has the original factory clutch! The only parts replaced have been 3 wheel bearings (the passenger side rear is still original), 1 alternator, 1 cv shaft on drivers side, and of course brake rotors and pads and tires. If you have 100000 on yours it's not even broken in yet if u take care of it. These things have to be made with alien technology..... They are almost indestructible. It also doesn't burn a drop of oil between changes every 3500 miles. Shooting for half a mil! And yes..... Original water pump too!!
#256 |
![]() Drives: 2008 Yaris white Join Date: Dec 2009
Milage for Yarrie 2022
I put all those miles on myself. I drove cross country once. Go Yarrie 2008. She has a leak somewhere letting in water in the trunk, but two washed clothes at a time take care of that.
#257 | |
![]() Drives: 07 Yaris Sedan S Join Date: Nov 2009
We are now in 2022 with 203,000 thousand miles :D. I have been a lurker but this forum has been a resource for a lot of troubleshooting of my car. So thank you for that. As I have had the car since 2007 and done some work on it I may start posting a bit more when I work on the car. |
#258 |
![]() Drives: 2007 Toyota Yaris 3DR Join Date: Feb 2010
225,000. Wife ran smack dab into a parked truck's trailer hitch going about 35MPH. I thought it'd be totaled. I bought two new bumper brackets, repaired a gapping hole in the bumper cover, painted it. Almost like new again. No mechanical failures to date.
#259 |
currently sitting in the mid 160k(kilometers) so probably over 100,000 ish, only annoying rattle is a common one, paints still good EXCEPT the roof where wifes surfboards would drip salt...but its just clear coat, no major repairs dents or otherwise couple penny size dings and some hood chips..the rear leaks SOMEWHERE when it POURS and its only very little, on either side under the side cargo trays at the very trunk end....i know its not the hatch seal as i modded the latch so it shuts a lil tigher a long time ago when i thought it was letting alot of water in
still tight n crisp everywhere...laugh at the low mileage all you like but its been a daily driver all its life.and ALWAYS outside...wife bought it new in BC living in victoria..so on an island milage doesnt rack up all that fast, in the past 7 or so years weve doubled the milage since being stateside only real thing showing wear is the drivers seat side bolster(left hip)..not a speck of rust and in all honest the paints so nice i dont see a repaint any time in the forseable future...aside from likely the roof between the drip rails aside from tire and brakes(another set of both before summers out) nothings really been replaced, heck the original headlight bulbs were swaped for HIDs a few months back, and i swapped out the driver door seal due to "yellowing"..headlights have to get swapped out this year tho as the "crazing" is far to bad to polish out...its on the inside of the lensing |
#260 |
![]() ![]() Drives: 2010 3dr LB Join Date: Sep 2010
Just turned 200,000 miles on my 2010 2 door hatchback with 5 speed manual. Only non wear items replaced were cam position sensor and the alternator. Best and most reliable vehicle I have owned. Bill C
#261 |
![]() Drives: 08 Yaris Base 3dr Join Date: May 2022
178xxx as of now. Excited to get to 200,000 miles. ^also named Bill
#262 |
![]() Drives: 2006 Yaris 2dr hb manual Join Date: Oct 2021
I'm at 135k (218k km's) now but only had the car for 2 years. I just did a bunch of work to it so I expect it run fine without any major work for another 100k. I'm constantly amazed at how a 17 year old car can still be a strong daily and run so well.
#263 |
Average KKT User
Drives: 2001 Echo Join Date: May 2020
2001 Toyota Echo with just a couple miles
![]() (100% totally legit not a fuck up reprogramming the mileage) |
#264 |
I now have 120,000 miles on my 2008 Yaris. She has a dent from a recent hit, and a leak somewhere in the back, which tape is helping with. I'm trying to get a picture of my mileage, but for some reason, it is hard to get the picture to post here. [IMG]mileage3212024[/IMG]
#265 |
100k is nothing on a Yaris. Our '10 (which is now my 16 year old's) is at 170k
If you want to enjoy your car, stay off of the internet. |
#266 |
![]() Drives: 2009 Black Hatchback Join Date: Feb 2021
168,000 on my 2009 hatchback I bought in 2016 with 86,000. I’ve only ever done general maintenance, a serpentine belt , rear brakes , battery and tires. It spent 7.5 years with me in Los Angeles and that city is rough on cars. The driver door was hit and ran years back leaving a dent bad enough it would require to much filler and the bumper cover was ripped off by a reversing tow truck. I just got a new bumper cover free and am searching for a replacement door. I’m going to try to cosmetically clean it up.
#267 |
I just turned 235,000 miles on my 2010 3dr manual. Bought new in Sept 2010, 5000 mile synthetic oil changes. Only stranded once by a bad Crank Position Sensor, Replaced alternator and left rear wheel bearing. Tires, brakes, and battery replaced. Bill C
#268 |
![]() Drives: 2015 three door, polar white Join Date: Jun 2025
128K at 10 years old.
Replaced water pump @ 60K--warranty. Plugs and flush coolant at 118K Alternator/belt at 128K Synthetic oil evert 4-5K changed w/filters Tires at 60K and 98K New battery every 5 years (gel) so I'm on the 3rd battery Just saw one like this going for $13K; I paid $16.5K |
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 02:06 PM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 01:40 PM |
| 11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) | Jerkratt | NY / NJ/ CT / PA | 14 | 10-26-2008 06:51 PM |
| Japanese Mix Club Los Invitamos!!! | TunTun_yariS[PR] | Caribbean | 0 | 12-12-2006 01:03 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 07:55 PM |
