![]() Drives: Yaris Join Date: Dec 2020
2ZRFE and manual swap 2007 hatchback
Hi all,
Long time lurker first time poster. I finally managed to kill my 1NZ engine, which means I have a good excuse to do this swap. I also want to swap out the auto trans for a manual while I'm at it. Over the last couple of years I've read every 2zr swap thread I can find on here and have started putting together a shopping list, I'm hoping some of you can critique it and let me know if I'm heading in the right direction or not. I have watched the MCM Yaris Hilton videos many times over, to be honest I'm still wrapping my head around how they did a few things. Also I'm in Australia, hence leaning towards as many Corolla parts as I can, though I'm happy to get my hands on some of the Scion xD parts to make the swap easier, and avoid fiddling with electronics as much as possible. My list for the engine swap: 2ZRFE engine (from Corolla) ECM (from manual Corolla) Engine Harness (from manual Corolla) Body Harness (keep from Yaris?) Alternator (Corolla) AC Compressor (Corolla) MAF sensor and intake (Corolla) Exhaust (from Corolla) Passenger side mount (from Scion xD) Engine side mount (from Scion xD) For the transmission swap: Manual Transmission (from donor manual Yaris) Clutch (donor Yaris) Flywheel (donor Yaris) Shifter (donor Yaris) Shifter cable (donor Yaris) Clutch pedal (donor Yaris) Brake pedal (donor Yaris) Clutch Master line (donor Yaris) Slave cylinder line (donor Yaris) Brake master cylinder (donor Yaris) Relevant brackets / hardware (donor Yaris) My questions: Should I look for an ECM / harness from a manual Scion xD instead of from a Corolla? Any particular model Corolla I should look for? I was keeping my eye out for a 2010. Any tips on avoiding immobilizer issues? I appreciate anyone who wants to chime in. If there's any necessary reading you think I've missed please share. Thanks in advance! |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Good luck with the swap!
It also blows my mind that people actually manage to kill a stock 1NZ/2NZ, they are just such good little engines.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
Gen 3 > Gen 2
delete
Thanks mate!
To be honest I really neglected my poor Yari for a good decade, it's a Toyota miracle she lasted that long. |
![]() ![]() Drives: '07 Yaris Liftback Join Date: Jul 2007
Your list looks mostly complete:
-Yaris body harness: keep -AC: You'll also need hoses and I recommended swapping the condenser for a new one. Flushing it will be a pain. On engine and harness: I recommend going with the Scion XD ECM and engine harness if possible. This will reduce manual wiring to just a couple wires and ensure compatibility with the body harness. Additionally, a US Scion XD ECM will not have an immobilizer, which should mean it will work with any engine/body. If you want to maintain the immobilizer, then I'd suggest going with a Corolla ECM and getting your keys reprogrammed. A Corolla engine harness with a Scion XD ECM should work, but you'll want to check the pinout on both to make sure these match up. Keep in mind, the ECM and harness is also transmission specific, i.e. manual ECM and harness can only be used with a manual transmission. |
#6 | |
Appreciate your wisdom! |
All of these are ECMs from Manual XDs from 2008-2014. Just heads up that Canadian XDs got an immobilizer and have the same part numbers. I would check with the seller if they have the VIN so you can double-check.
89661-52F81 89661-52F82 89661-52F83 89661-52M10 89661-52T90 89661-52Y50 |
#8 | |
Gen 3 > Gen 2
Auto engine harness can also be used with a manual(but not the other way around) but you'll have to add or transfer the wires from the Yaris engine harness for the reverse lights over to the Scion harness to make them work.
Awesome, thank you both. I do remember reading that from one of Armstrong racing's posts.
The manual Scion harnesses seem to be rarer than hen's teeth, so very good to know... |
Drives: 2008 Yaris Join Date: Nov 2024
Curious how this is going, I'm in aus too and just successfully finished my own swap. Has anyone else encountered a P0453 code after doing the swap? I used an XD ecu and I suspect the culprit is my lack of a charcoal canister, but I'm not really sure at this stage.
Good timing, I have just got the engine in, and now I'm trying to make sure I have the speed sensor wiring correct. How did you do yours?
Can't help you on the error code sorry man - not that far ahead yet! |
All good, hopefully I’ll figure it out eventually. I got a 2017 corolla 2ZRFE from a wreckers, keeping my yaris 5 speed mt so fortunately didn’t have to worry about speed sensor stuff. Somehow managed to find a manual xd ecu on ebay as well as an auto engine wire harness - I just swapped over the reverse sensor wires into the yaris connector. Xd rh mount and bracket + bottom mount from amayama/rockauto and xd shift cables from ebay. Engine sits a tiny little bit crooked because its missing the lh xd bracket on the transmission but a big push and it went in just fine. Hot tip, not sure if you’ve tried to start yours yet - i didn’t realise my ecu had an immobiliser, but I was able to reset it to my existing keys by bridging pin 4 and 13 in the obd2 port and leaving the car in start for 30 mins. Sounds weird but it worked.
| The 2zr-fe engine swap guide | ArmstrongRacing | Performance Modifications | 416 | 08-14-2023 03:14 PM |
| THE 2ZRFE engine swap thread - Just the facts | brushforhire | Performance Modifications | 40 | 12-24-2019 11:08 PM |
