#73 |
![]() Drives: Yaris Join Date: Feb 2014
Someone asked me to repair their clock, I took a better picture of the fix + the test setup.
#74 |
![]() Drives: Yaris 2006 Join Date: Jan 2019
Is there anyone out there who managed to fix it by replacing the transistors? I'd need the dimming feature.
#75 |
Okay, so I've pulled it apart today and resoldered the transistors, as mentioned by a comment on sven337's page. I don't know if this will last, because when I start the car the clock display comes on pretty slowly, which tells me that something isn't quite right, although I don't remember how it used to be. But at least it works for now.
@sven337, do you think that there is any risk of fire when the transistors die? I can imagine there is quite some heat if it's enough to make the PCB turn brown on the other side. |
#76 |
![]() Drives: Yaris 1,3 2007 Join Date: May 2020
Hi guys,
I tried sven337 solution but with 1,5V the clock is not bright at all. When i adjust it at about 2,7V to be brighter then the red lines appear. When the lights are turned on, the clock is not readable! Great work though for sven337 and all the rest!! |
#77 | |
Any ideas how to do the boost converter mod with retaining the dimming feature? |
#78 |
Drives: yaris 2007 Join Date: Mar 2022
Hello,
As others on this thread, I have the clock/temperature/ average consumption display problem. The thing is that I just bought the car second hand 2 weeks ago. I didn't see that missing display until I drived it several days, asking myslef how possible it was for a car not to have a clock ( I use to have the Yaris 2004 before, that has all those features) The person that sold it to me ( herself 2nd byuer) said that she never paid attention to that and that it was surely already out when she bought the car 5 years ago ). Anyway, I've found this thread via the french page of sven. The problem is Im not equiped (and talented) to start trying taking all those pieces out :/ I saw on the thread that you can find the full part with the screen etc but it is 150 € ! My questions are : - is there a way to find just the electronic panel , cheap, and to replace it ? - how expensive would it cost to me if I go to a toyota garage and ask them to repair it ? Also, if you know someone in Belgium that would accept to do the work for me in exchange of of a good price, Im interested :) Oh, and I also have the "turning button" to change from outside/recycling air" that is blocked on the " outside air" , but I hope it is just a plastic thingy blocked behind the n panel, nothing electronic here) Thanks a lot ! Regards, Dreamer |
#79 |
Drives: Yaris 2006 Join Date: Apr 2022
Is it possible to replace the old faulty cluster with a second hand unit that works?
Or will that mess up ODO etc? |
#80 |
![]() Drives: Yaris 2006 - 1.0 Join Date: May 2022
Well, my Yaris 2006 had the same issue 1 month ago, yesterday i decided to do the procedure mentioned here, thanks to Sven337 !!
All worked Now, i decided not to remove the transistors, i just added the MP1584EN, and in this way, the dim functionality continues to work.. If anyone needs pictures i can post them, i took some. Thanks! |
#81 |
Drives: yarish Join Date: Sep 2022
could you send me the photos of the modification?
#82 | |
![]() Drives: Toyota Yaris Join Date: Nov 2022
Another one with the same problem. Thanks to sven337's posts, I'll try to follow his procedures as well. In your case, you decided not to remove the transistors. You say that this way the variable brightness functionality remained functional. Can you confirm that everything is back to normal after the repair and no more problems have appeared? I'm thinking of a more complex repair, but just in case it's justified! Thanks |
#83 |
Here is the solution I implemented.
#84 |
#85 |
Drives: toyota yaris Join Date: Dec 2025
Please, I'm looking for the wiring diagram for the connector.
#86 |
Drives: toyota yaris 2006 Join Date: Mar 2026
Muchisimas gracias a sven337 por la información y a adsb por las imágenes proporcionadas sois unos putos Top Globales y unos máquinas.
Gracias a este foro y toda la información que hay aquí intentaré arreglar la pantalla del yaris y sino lo consigo ha sido un placer enloquecer junto a ustedes Last edited by magicyaris; 03-18-2026 at 11:32 AM. |
#87 | |
Drives: Yaris Join Date: Jul 2026
| GI: "YarGauge" replacement clock module (Digital Tach, etc.) | CTScott | Items for Sale by private party | 756 | 03-21-2013 08:22 PM |
| 05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 04:34 AM |
| Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 09:22 AM |
| Dashboard remove ... ALL of it | Toji | Cosmetic Modifications (Exterior/Interior) | 7 | 02-26-2011 06:30 AM |
| Setting the clock after DST change | ToddR | DIY / Maintenance / Service | 10 | 03-09-2009 11:33 PM |
