Old 08-02-2026, 02:50 PM   #38
asura6
Drives: Yaris NSP130
I successfully installed the cruise control on a 2012 french made 1.3 L 6-speed Yaris. 1NR-FE. This version of the car had a different way of removing the steering pad as it had only one hole for accessing the clips which was located around 6-o'clock. You remove the steering pad by pushing a screwdriver through the hole to disengage the bottom clip and then you can disengage the other clips by pushing the steering pad upwards just using your hands. My steering wheel had audio buttons and and call buttons. There was a vacant 4-pin connector that I simply plugged in the cruise control stalks connector into and it started working.
asura6 is offline   Reply With Quote
Tags
cruise control. 2012
